Aluminum Upper Control Arms for 63-82 Corvettes: Natural Finish, Performance Ball Joi
Former Vendor
St. Jude Donor '13
Aluminum Upper Control Arms for 63-82 Corvettes: Natural Finish, Performance Ball Joints
http://www.xplosiveperformance.com/A...ts_p_1932.html
$765.95
SpeedDirect's aluminum control arms greatly improve your suspension geometry which directly translates into improved handling and cornering ability.
This kit provides increased positive caster for greater stability and improved bumpsteer, while relocating the front roll center for superior handling. They are also lighter than both stock and steel tubular control arms.
Each side is 4 lbs less than the stock control arm, resulting in an 8 lb weight savings!
Designed as a true bolt-on kit, these control arms do not require any modification to the vehicle.
Kits are available in natural or polished aluminum finishes and come complete with clear instructions, bushings, cross shafts and optional ball joints.
MADE IN THE USA!
Take a Step Better
63-82 SB Corvette Front Tubular Control Arms & Coilover Package
$765.95
MADE IN THE USA!
Take a Step Better
Aluminum control arms greatly improve your suspension geometry which directly translates into improved handling and cornering ability. This kit provides increased positive caster for greater stability and improved bumpsteer, while relocating the front roll center for superior handling. They are also lighter than both stock and steel tubular control arms. Each side is 4 lbs less than the stock control arm, resulting in an 8 lb weight savings! Designed as a true bolt-on kit, these control arms do not require any modification to the vehicle. Kits are available in natural or polished aluminum finishes and come complete with clear instructions, bushings, cross shafts and optional ball joints. MADE IN THE USA!
New concept -The ONLY custom aluminum a-arms for 63-82 Corvettes available.
Improved geometry over tubular a-arms currently on the market.
Heat treated cast.
Rulon bushings - high performance fluoropolymer composite bearing (similar to Teflon).
Compatible with stock ball joint dimensions.
Available with stock (Moog) or performance ball joints (which provide even better roll center geometry and more camber gain than stock ball joints).
Works with all other stock suspension parts.
Lighter weight than stock or tubular A-Arms.
Changes caster, camber and roll center for improved handling.
Design strength safety factor of 5X - Stress / failure analysis results in 5X required load strength.
STEEL Tubular Lower A-Arms for Stock Coil Spring & Shocks or Front coil over kits
Steel tubular lower control arms include:
Both left and right tubular control arms
.120 Wall Thickness
2.25 lbs Lighter than Stock - Per Arm
Powder Coated Black
Comes With Ball Joints
Delron Bushings
Single-Adjustable Shocks w/ Soft Springs (400 in/lb) with Small Block.
This Single-Adjustable Shocks w/ Soft Springs (400 in/lb) coil over front spring and shock packages for 63-82 Corvettes allow for easy ride height changes without the need to disassemble the suspension. They also allow you to adjust the individual loads on each corner of the car for better, more balanced handling. The different spring rates available offer a smooth ride with great handling, unlike other bouncy front suspension conversions. All QA1 shocks are cutting edge race designs with velocity sensitive valving. Whether you have a full time race car or a street car, these shocks will provide the best performance and ride quality available. Single adjustable shocks are adjustable in rebound and compression with the easy twist of one dial.
http://www.xplosiveperformance.com/6...ge_p_3010.html
$2475.89
Heat treated cast.
.120 Wall Thickness
Powder Coated Black
Delron Bushings
$2475.89
Former Vendor
St. Jude Donor '13
$765.95
MADE IN THE USA!
Take a Step Better
$765.95
MADE IN THE USA!
Take a Step Better
Heat treated cast.
.120 Wall Thickness
Powder Coated Black
Delron Bushings
$2475.89
Heat treated cast.
.120 Wall Thickness
Powder Coated Black
Delron Bushings
$2475.89
Former Vendor
St. Jude Donor '13
$765.95
MADE IN THE USA!
Take a Step Better
$765.95
MADE IN THE USA!
Take a Step Better
Heat treated cast.
.120 Wall Thickness
Powder Coated Black
Delron Bushings
$2475.89
Heat treated cast.
.120 Wall Thickness
Powder Coated Black
Delron Bushings
$2475.89
Former Vendor
St. Jude Donor '13
$765.95
MADE IN THE USA!
Take a Step Better
$765.95
MADE IN THE USA!
Take a Step Better
Heat treated cast.
.120 Wall Thickness
Powder Coated Black
Delron Bushings
$2475.89
Heat treated cast.
.120 Wall Thickness
Powder Coated Black
Delron Bushings
$2475.89
Former Vendor
St. Jude Donor '13
$765.95
MADE IN THE USA!
Take a Step Better
$765.95
MADE IN THE USA!
Take a Step Better
Heat treated cast.
.120 Wall Thickness
Powder Coated Black
Delron Bushings
$2475.89
Heat treated cast.
.120 Wall Thickness
Powder Coated Black
Delron Bushings
$2475.89
Former Vendor
St. Jude Donor '13
$765.95
MADE IN THE USA!
Take a Step Better
$765.95
MADE IN THE USA!
Take a Step Better
Heat treated cast.
.120 Wall Thickness
Powder Coated Black
Delron Bushings
$2475.89
Heat treated cast.
.120 Wall Thickness
Powder Coated Black
Delron Bushings
$2475.89
Former Vendor
St. Jude Donor '13
$765.95
MADE IN THE USA!
Take a Step Better
$765.95
MADE IN THE USA!
Take a Step Better
Heat treated cast.
.120 Wall Thickness
Powder Coated Black
Delron Bushings
$2475.89
Heat treated cast.
.120 Wall Thickness
Powder Coated Black
Delron Bushings
$2475.89
Former Vendor
St. Jude Donor '13
$765.95
MADE IN THE USA!
Take a Step Better
$765.95
MADE IN THE USA!
Take a Step Better
Heat treated cast.
.120 Wall Thickness
Powder Coated Black
Delron Bushings
$2475.89
Heat treated cast.
.120 Wall Thickness
Powder Coated Black
Delron Bushings
$2475.89
Former Vendor
St. Jude Donor '13
Started on Monday November 18, 2013 We have launched our
XP Motorsports/Xplosive Performance Customers Reward Point Program
Reward Point Program Explanation & FAQ
What is the Reward Point Program?
To thank you all for your continued support and to offer you future incentives we would like to give you something back, this is why we have launched our great
XP Motorsports Customers Reward Point Program.
Our Customers Reward Point Program is as simple as it sounds.
While shopping at XP Motorsports/Xplosive Performance you will earn Reward Points for the money you spent. Once earned, you will be able to use those points to pay for future purchases at XP Motorsports/Xplosive Performance.
How does the Program work?
When you place an online order, the total amount of the order will be used to calculate the amount of points earned. These points are added to your Rewards Points account. For every ($1) Dollar you spend you will earn ($0.10) for future purchases. All reward points are listed in your account and will stay there until used by you.
Ready for you to spend on whatever you want.
Reward points will expire after two (2) years but can be accumulated during that time until you decide to use them.
You must login to your account in order to view the status of your points. During the checkout process you'll be able to pay for your order with your rewards points balance.
Points and Values
For every $1.00 spent at XP Motorsports/Xplosive Performance you will earn .10 point.
For example:
Buy a set of Pads for $301.00 = 30 Reward Points.
Each product will have a Reward point valve. Along with the add to cart box you can elect to pay for your next purchase with your Reward Points
Redeeming Shopping Points
If you have a balance in your Rewards Points Account, you can use those points to pay for purchases made at XP Motorsports/Xplosive Performance. On your next purchase you can check the [Redeem this Item for (x) points]. You can then redeem your reward points. Once confirmed your order will be shipped, your Rewards Point account will be updated and the points used will be deducted from your balance
Points and Values
For example:
Former Vendor
St. Jude Donor '13
$765.95
MADE IN THE USA!
Take a Step Better
$765.95
MADE IN THE USA!
Take a Step Better
Heat treated cast.
.120 Wall Thickness
Powder Coated Black
Delron Bushings
$2475.89
Heat treated cast.
.120 Wall Thickness
Powder Coated Black
Delron Bushings
$2475.89
Points and Values
For example:
Points and Values
For example:
Former Vendor
St. Jude Donor '13
$765.95
MADE IN THE USA!
Take a Step Better
$765.95
MADE IN THE USA!
Take a Step Better
Heat treated cast.
.120 Wall Thickness
Powder Coated Black
Delron Bushings
$2475.89
Heat treated cast.
.120 Wall Thickness
Powder Coated Black
Delron Bushings
$2475.89
Former Vendor
St. Jude Donor '13
EARN YOUR XP MOTORSPORTS REWARD POINTS WHEN YOU ORDER ONLINE
http://www.xplosiveperformance.com/R...ram_ep_29.html
#34
Former Vendor
St. Jude Donor '13
EARN YOUR REWARD POINTS FOR FUTURE PURCHASES EARN $1.00 for every $10.00 Spent
ORDER ON LINE AND SCHEDULE YOUR INSTALL
Join us on Facebook
Join us on Facebook
#35
Former Vendor
St. Jude Donor '13
Join us on Facebook
Join us on Facebook
#36
Former Vendor
St. Jude Donor '13
Join us on Facebook
Join us on Facebook
#37
Former Vendor
St. Jude Donor '13
EARN YOUR REWARD POINTS FOR FUTURE PURCHASES EARN $1.00 for every $10.00 Spent (Points Good for (3) Years)
Join us on Facebook
Join us on Facebook
#38
Former Vendor
St. Jude Donor '13
$765.95
MADE IN THE USA!
Take a Step Better
$765.95
MADE IN THE USA!
Take a Step Better
Heat treated cast.
.120 Wall Thickness
Powder Coated Black
Delron Bushings
$2475.89
Heat treated cast.
.120 Wall Thickness
Powder Coated Black
Delron Bushings
$2475.89
#39
Former Vendor
St. Jude Donor '13
$765.95
MADE IN THE USA!
Take a Step Better
$765.95
MADE IN THE USA!
Take a Step Better
Heat treated cast.
.120 Wall Thickness
Powder Coated Black
Delron Bushings
$2475.89
Heat treated cast.
.120 Wall Thickness
Powder Coated Black
Delron Bushings
$2475.89
#40
Former Vendor
St. Jude Donor '13
$765.95
MADE IN THE USA!
Take a Step Better
$765.95
MADE IN THE USA!
Take a Step Better
Heat treated cast.
.120 Wall Thickness
Powder Coated Black
Delron Bushings
$2475.89
Heat treated cast.
.120 Wall Thickness
Powder Coated Black
Delron Bushings
$2475.89
