FS - #069 427/425 Horse Intake Manifold
I have a 427/425 horse intake manifold to sell. It's in good shape with no apparent weld repairs or damaged threaded holes but there is a slight bit of corrosion present on one side of the front water passage crossover that should seal adequately with silicone sealer. It has been bead blasted and has a light thin satin coating that used to be offered by Eastwood for aluminum intakes.
Although I've seen some of these intakes with two slotted carb surface openings and others with one side slotted and the other as two circular openings, I suspect someone milled open the one side with the two circular holes.
This might have been an over-the-counter purchase as the date is 10-13-67. Price: $450 + Shipping.
More pics can be seen on my Photobucket account.
http://s217.photobucket.com/albums/c...ke%20Manifold/
Mike T.
Mike T.
Last edited by Vet65te; 11-05-2012 at 12:12 PM. Reason: Added comment about bead blasting and Eastwood brush-on coating.
On this intake, it was never drilled and pipethread-tapped and that was one reason, along with the casting date, I thought it was an over-the-counter purchase. Later Bigblock heads had threaded holes for temp senders, I thought the early ones did too since this one was cast in late '67.
Mike T.
Mike T.
