Aluminum Heads Wanted
Received 1,762 Likes
Do yourself a favor,and use AFR heads, they are worth the difference in price. If you're serious just call,and talk with Tony or Jeremy. My guess is the 180 for a street 350 or the 195 for a 383-406. The mid range and throttle response is where AFR shines and that is 90% of street driving. You won't give up a thing on the top either. My next head will be AFR. good luck. Ron B.
if not going with a good cam 205 would be the most. I really like the trick flow heads. I have 225 on my c5 402 block. and love them. Old set up was on a N/A motor and was dart.
i have a set of afr aluminum heads that are fresh from Wayne Calvert Engines machine shop. they are 210 runners, 62 cc chambers, 2.08 intake/1.6 exhaust, 230 # springs. These heads come with ARP head bolts, rocker arm studs and afr push rod guides. I also have a complete set of Crane "Gold" aluminum roller rocker arms with 8.050 push rods.
interested if the above folks are not please pm me and thanks
