I have a 350 engine for sale. It is an L98 long block.
This engine would be good to run on a daily basis while saving the original engine for a rebuild or keep from wearing it out while you enjoy the car.
This engine is a late model one piece seal full roller engine with a right hand dipstick. less than 50,000 miles, (all with an overdrive trans) and had Mobil 1 used in it exclusively.
It had a TPI on it, and I used that on another project.
THis is an iron head block with 64 cc heads that uses regular gas. It has the TPI cam in it and will pass smog inspection up to the 1992 year emissions requirements. (with all the smog equipment) if need be.
It is black from the factory, and has no leaks. It is almost clean enough to eat off of....as I said, no leaks.
This engine comes with block, crank, heads, roller cam, roller lifters, dog bones, spider, pushrods, guided rockers, rocker covers, timing gears and timing cover, oil pan, harmonic balancer, and correct weighted flex plate.
It is assembled and on my run stand to demonstrate it if you are interested.
I am asking $600 for this engine in ready to run condition. Just add your intake, ignition, accessories and exhaust.
Currently it has a manifold and carb for demonstration purposes.
NOTE:
The accessories bolted to it are the items that stay with the run stand.
Should you want a serpentine belt system, my friend has one for $275 plus shipping.
For extra cash, I can come up with some v belt items as well. (alternator, water pump, or generator, and some pulleys.
I have pics of it on the run stand if you so desire. As I said, the run stand stuff stays.
My email is hillenger512@cox.net
Let me know...............
Chris
