C1 & C2 Parts C1 & C2 Corvette Performance Parts, Rare NOS and NLA Chevy Parts, Wheels & Tires, Exterior Enhancements, Aftermarket
F/S HEI HO Distributor 1104067
Old 07-06-2009, 02:46 PM
Oriondriver
Oriondriver's Avatar
Default F/S HEI HO Distributor 1104067
****SOLD***
New in box...
01104067 - HEI HO Distributor. This distributor has the melonized cam drive gear P/N 10456413 for steel roller camshafts. This distributor is required on all crate engines and roller camshafts that are made of steel. If engines are assembled not using this gear, it may affect your engine warranty. Use connector wire P/N 8917052 to ignition. Used with all small and big-block V8 High Output engine assemblies. Technical Notes: Components in these groups are interchangeable with small-block Chevrolet V8s. GM Performance Parts distributors cannot be used with “tall deck” Bow Tie block P/N 14044808.
(Discontinued) Use either P/N 93440806 or P/N 88961867 as the replacement.
Cast aluminum distributor for all small-block and big-block V-8 engine assemblies. High performance mechanical advance curve. Vacuum advance canister included. Use connector P/N 12167658 to attach tachometer and 12-volt power supply wire to distributor.
Used with all Small and Big-Block V8 High Output engine assemblies. The built-in ignition advance curve is suitable for high-performance applications.
Retail $333.05
$175 plus shipping takes it... or make me an offer!
Scott
Old 08-31-2009, 09:17 PM
johndoby
johndoby's Avatar
You've got mail.
Old 03-24-2010, 12:26 PM
Oriondriver
ttt
Old 03-29-2010, 04:27 PM
jammasterj787
1st Gear
jammasterj787's Avatar
you got a pm
To F/S HEI HO Distributor 1104067
Quick Reply: F/S HEI HO Distributor 1104067
