Corvette Forum
Go Back   Corvette Forum > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Parts
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C1 & C2 Parts
C1 & C2 Corvette Performance Parts, Rare NOS and NLA Chevy Parts, Wheels & Tires, Exterior Enhancements, Aftermarket Sponsored by
ProTeam
Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-14-2008, 11:55 AM   #1
oseman2
Junior Member
oseman2's Avatar
Default 1965 Corvette engine wiring harness question
Hello!
I am installing a LS2 in a 1965 vett. The custom harness I have, and obviously a regulated alternator, doesnt require a voltage regulator and I would like to eliminate it form my harness. It looks like I can easily remove most of the wires but I dont know what the black and pink wire coming from it are for. The wire travels through the firewall, turning to brown in color at the firewall connector/junction. Any of you electrical experts willing to lend me a hand? I could eliminate all of the original harness but I would like to keep everything as original as possible except the drivetrain. Thanks!
oseman2 is offline   Reply With Quote
Old 11-14-2008, 06:09 PM   #2
ragtopman
CF Senior Member
St. Jude Donor '10-'11
ragtopman's Avatar
That black with pink trace wire, in a original harness goes from the ignition switch to a ballast resistor, then to the pos. side of the coil then to the R side of the starter. It also goes to the back up lamp switch and lamps(if you have them), fuel tank sender and gas gauge, temp gauge and park alarm lamp. It also goes to the volt. reg., but it shouldnt turn into a brown wire. Hope this helps.
ragtopman is offline   Reply With Quote
Reload this Page 1965 Corvette engine wiring harness question
Tags
1965, alternator, correct, corvett, corvette, engine, harness, pink, routing, stingray, vett, wire, wiring
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
