327 365HP Cam and Lifter set GM #3849346 specs
Correct 365 hp cam and lifter (solid) set, same specs as the GM #3849346 327ci | 365HP small block Chevrolet engine cam. Cam was new and was run for less than 500 miles and broken in perfect - no scoring. Lifters are BRAND NEW [$121.00].
Camshaft & solid lifter set specs:
Basic operating RPM range: 2,800-6,800 RPM
Camshaft style: mechanical flat tappet
Cross reference: GM #3849346
Duration (@ 050 inch lift): 254 int. / 254 exh.
Duration (advertised): 346 int. / 346 exh.
Lifters: Solid
Lobe separation (degrees): 114
Valve lash: .024 int. / .026 exh.
Valve lift (w/factory rocker ratio): .485 int. / .485 exh.
Paid $239 for cam and lifters.
Asking only $109 for the set
SOLD
-Chris
Lifters: Solid
SOLD
-Chris
Duke, it's for sale again. I never received payment from the buyer and I don't have his number.
It's up for sale again!
-Chris
-Chris
Please note: This cam is not GM. It's a newer solid cam with the same spec grind as the 365hp cam.
The lifters are brand new, the cam was run for less than 500 miles and broken in correctly.
-Chris
-Chris
Searching for buyer! Need address. Never sent return address for Michigan. I've called and left a message.
Call me
-Chris
Call me
-Chris
