Corvette Forum
Go Back   Corvette Forum > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Parts
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C1 & C2 Parts
C1 & C2 Corvette Performance Parts, Rare NOS and NLA Chevy Parts, Wheels & Tires, Exterior Enhancements, Aftermarket Sponsored by
ProTeam
Corvette
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Closed Thread
Old 07-08-2007, 12:58 PM   #1
JRD77VET
CF Senior Member
St. Jude '03-'04-'05-'06-'07-'08-'09-'10
Support Corvetteforum!
JRD77VET's Avatar
Send a message via AIM to JRD77VET
Default [SOLD] four 15 x 7 Ralley rims with trim rings ( off '72 monte carlo )
SOLD
I have four 15 x 7 ralley rims with trim rings off my '72 Monte Carlo. These are NOT the deep dish 15 x 7 used on the '68 corvettes.
The back spacing is 4-1/4" . Trim rings are not perfect, they do have curb scratches. But they are shiny.
Price is $140 for the set of four. Thanks for looking
Jeff
JRD77VET is offline
Old 07-09-2007, 11:05 AM   #2
67 3X2
CF Member
Will These Fit My 67 Vette?i Am Looking To Put Bias Tires On Theme For Show.are These Coded Or Are They Repro?i Am In Bucks Co.pa Brian
67 3X2 is offline
Old 07-09-2007, 11:11 AM   #3
67 3X2
CF Member
I Have Seen Rims 15x6.what Does The 15x7 Mean?brian
67 3X2 is offline
Old 07-09-2007, 09:06 PM   #4
JRD77VET
CF Senior Member
JRD77VET's Avatar
Quote:
These are the original rims off my '72 Monte Carlo that I purchased in 1981. I will look for codes if someone describes what to look for.
Brian, what area of Bucks County are you in? I'm not too far from the northwest corner. If it's not too far for me, I could bring the rims over to check out the fitment. ( if you're serious about buying them - provided they fit)
These rims are 7" wide.
Jeff
JRD77VET is offline
Old 07-09-2007, 09:34 PM   #5
67 3X2
CF Member
JEFF,I'M IN BEDMINSTER,PA WHICH IS 10 MIN NORTH OF DOYLESTOWN,PA.I'M SERIOUS, IF THESE RIMS WILL FIT MY CAR I WILL PURCHASE THEM.ARE THERE ANY STAMPING ON THE RIMS AROUND THE AIR VALVE?BRIAN
I WOULD ALSO LIKE TO OPEN THIS UP TO OTHER PEOPLE WHO HAVE RALLY WHEELS ON THEIR CARS.WILL THESE RIM WORK ON MY CAR?WHAT SIZE RIMS DID VETTES COME WITH FROM THE FACTORY?Any info would be apprec.Brian
67 3X2 is offline
Old 07-09-2007, 09:35 PM   #6
67 3X2
CF Member
I Forgot To Say.i Have A 67 427/435.
67 3X2 is offline
Old 07-09-2007, 10:07 PM   #7
ironarms
CF Senior Member
St. Jude Donor '05-'08-'09
ironarms's Avatar
jeff, if the previous poster does not take them i will i am about 30 minutes west of you in fleetwood
ironarms is offline
Old 07-09-2007, 10:12 PM   #8
JRD77VET
CF Senior Member
JRD77VET's Avatar
Ok Brian, just pulled off the trim rings to check codes.
Here's what I found, I'll use the same numbers as the runout numbers.
#1 Stamped on the inside, 15 X 7 JJ with a "C" under the JJ
on the outside, 11 ( valve stem) 30 with either a "P" or"F" then W
#2 Stamped on the inside, 15 X 7 JJ with a "C" under the JJ
on the outside, 11 ( valve stem ) F W
#3 Stamped on the inside, 15 X 7 JJ with a " K 1" under the JJ and a "6" under the K1
on the outside, K16 6 ( valve stem ) ( something ) W
#4 Stamped on the inside, 15 X 7 JJ with a " K " under the JJ and a "7" under the K
on the outside, K17 4 ( valve stem ) 19 F W
With the trim rings, one is the rim clip style and three are the "claw" style that grabs the rim.
I work in Telford right by the Telford exit of Rt 309
Jeff
JRD77VET is offline
Old 07-09-2007, 10:13 PM   #9
JRD77VET
CF Senior Member
JRD77VET's Avatar
Quote:
JRD77VET is offline
Reload this Page [SOLD] four 15 x 7 Ralley rims with trim rings ( off '72 monte carlo )
Closed Thread
Tags
15, 72, c1, carlo, monte, rims
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
