S/B oil pan
S/B oil pan
The oil pan I took off the car before it went to the shop looks to me like the correct oil pan but it is a bit battered. before I go to great lengths to straighten in out I just wanted to make sure it was correct. If its not I'll probably just get a cheep reproduction.
Here is a link to a picture of my oil pan.
Oil Pan
Is this a real oil pan for a small block with power steering. I couldnt find any numbers on it?
Oil Pan
Received 1,974 Likes
Don't think so. The large (mechanical lifter engines and maybe early L-79s) C2 pans have the drain plug at the very rear, centered laterally, and I believe the small pan drain plug is in the same location.
My understanding is that the big pan is reproed, but not the small pan, so they can be tough to find and expensive. It's also my understanding that these two pans were unique to Corvette engines and not shared with other Chevrolet models.
Most pans don't have a part number or other identifying nomenclature, so they can only be IDed visually based on geometry and other physical characteristics.
Duke
Duke
Received 1,858 Likes
Here's the correct 5-quart (4+1) SB oil pan - same general shape as the one in your pic, but the drain plug is centered at the rear:
I saw this one on ebay.
ebay oil pan
Wow If thats how much they go for I think I'll stick with mine. Maybe Ill try my hand at moving the drain plug with a welder.
ebay oil pan
ebay oil pan
ebay oil pan
I went through this about a year ago and the picture that John posted was of the 1st pan I bought.
I purchased the 5 qt for about $90 on EBAY and found out it wasn't the one with the trap door (6 qt). I subsequently found a trap door pan on EBAY for about $130 (came with a bunch of other stuff I have sold for $100) and ended up selling the 5 qt on EBAY again for $100. Unless oil pan prices have gone through the roof in one year all you have to do is wait and you'll find something reasonable. Both were original small seal pans.
The funny thing about both auctions I won is that neither was advertised as "CORVETTE". Probably why the price was reasonable.
Brian
PS both pans needed to be stripped, de-scaled, and repainted as someone had "restored" them by paining over rust. Both pans have very minor dents.
Brian
The word corvette usually adds a few hundred $ to the price of anything. The numbers 67 and 427 usually adds a few thousand $ to anything.
Are there any other oil pans that have the drain plug in the back and look like that that are not corvette oil pans?
ebay oil pan
ebay oil pan
I bought a 5 quart Corvette pan on ebay to replace the stock 4 quart (center drain plug) pan that I ended up using when the engine blew. These 5 and 6 quart pans come up fairly often on ebay. Most will probably need some reconditioning as received but at least you will have a real Corvette oil pan to reinstall back into your car. The rear drain plug oil pans were Corvette only.
John
The 6 qt pan was unique to Corvette and was used in HP engines. The big difference is in the baffling and rear swinging door. Under certain conditions it helps to keep the oil from draining away from the oil pump.
Also, a good deal of HP is robbed when crank dips in the oil or excess oil goes on the crank. This was discovered many years ago by Moroso Performance. They design pans and baffling to control the flow of oil to keep it away from the crank and near the oil pump. Check out their catalog or go to moroso.com for more info and available items
