It's fall, mice again...!!!
I always keep baited mice traps in my garage. Durring the summer my garage was mice free. Not so since fall. Caught 4 in the last 2 weeks. Last one the Wall-mart trap caught his leg and the little critter was alive when I inspected the trap. Felt kind of sorry for the little guy as he looked up at me, but I had to kill him with a brick.
Hey, it's either them or my Vette.
I've owned the Vette for over 20 years and for the first 4 years I had no garage, so the car remained outside. Since new construction in the suburb where I live, mice have become more plenitful. That and recent composting in the neighborhood have seemed to attact more rodents. But no rats yet...
Since I don't have electricity in the garage I was wondering if anyone knew of any mice alarms that run off of batteries. I suppose I could buy a power invertor and connect one to a car battery, but how long before the car battery would be discharged.?
Thoughts.?
TIA
Kenmo
Thoughts.?
TIA
Kenmo
Bricks are kinda messy. I think a $30 BB gun would be better . Sounds like you've got a rodent problem that needs to be addressed. I suggest getting some poison from the local hardware store.
Vetterodder: I guess the $30 B-B gun would work on a small critter like a mouse, but it does NOTHING to the "PITTSBURGH PIGEONS" that have invaded my bird feeder! The B-B's just bounced off; I bought .177 pellets, and they, too, bounced off. Just bought .177 "bolts" (looks like a dart); will see what tomorrow brings!
Cruz
Cruz
Received 1,974 Likes
A lot of guys fret about "winter storage", but most of the same guys give no consideration to rodent control.
BY FAR the most storage damage is likely to occur from rodents. I keep traps under the car and elsewhere on the floor and bait in the engine compartment, interior, and trunk. You cannot be too cautious about rodent control. Use lots of traps and poison and make frequent inspections for activity.
Duke
Duke
I've had my share of mice in the garage, but usually wipe them out shortly after they take up residence. I have also tried to alter my habits (I used to tend to leave the garage door open a lot) to limit their opportunities to get in now. Seems to work. But I still keep traps around though (just in case)...
Don't forget to inspect for mouse nests in the spring before startup. They will cause a fire. A friend of mine parted out a '76 last year that burned due to a nest among header pipes.
Mothballs work great. I use mothball placing them on the inside, the motor area (use the net bags used for washing nylon socks) and under the car. I don't like to use traps. Also DCON those wedge shape boxes with poison works great too. Be careful if you have small pets. The critters like to nest inside exhause pipes too, so don't forget to block them up. I usually check the cars several time a week to make sure the little guys haven't taken up residence inside either the 63 or the 02. They will bite through wiring, seats, carpet and just about anything else that is not metal. Its a serious problem with mice. Also if you store car outside, cats, squirrels, racoon, chipmonks and other little critters wil nest inside the motor area if the car is covered up. Its a good idea to check. I know one guy who found a snake under is hood and he did not have a Cobra
Anyone use something like this....to keep the vermints away ?
http://www.safehomeproducts.com/SHP/...p#Weitech_0180
I've tried several of those sonic devices, they do not work. I had a spider building webs on one! By the way, even though I hate killing animals or even bugs, those pointy pellets should do the trick.
I've tried several of those sonic devices, they do not work. I had a spider building webs on one! By the way, even though I hate killing animals or even bugs, those pointy pellets should do the trick. Cats are definately a must if you have an infilltration but you have to get a mean alley cat, not one of those metrosexual cats.
I use them
The little bugger ran under the base of my drill press where he/she saw its last days. I gased little Mickey with the car exhaust through the bolt hole!
Since then I have had two of those sonic devices in the garage (16 months now), and have not seen a mouse yet. Don't know if it's the sonic device or the word is out on me but they havn't been back yet.
The spiders were building webs on them in the house, so I moved them out to the garage. Maybe the frequency is different and mice don't likem. I do keep decon by the roll up doors, but nobody's hungry!
Cruising
Got this one from guy at local car show-tried it-worked for
me. Sprinkle powdered laundry soap WITH BLEACH around
perimiter of storage area-the critters walk through it, then
lick it off their feet (must not like the feel or smell of it).
Works like D-Con but cheaper.
When I disassembled my 61 that the previous owner had stored for 15 years I found mice nests throughout the car. In the exhaust, in the seats, in the frame rails, in the heater box, in nooks and crannies throughout the fiberglass body, etc, The seat material as it was chewed up and used elsewhere in the car to make nests. When I had my frame repaired in two different rust out areas the welders said they had found nests in both spots. Keep those critters in check.They can raise heck with your stored car.
Frame Rails???
I found the jute from my carpet padding nicely tucked into the right side rear frame rail mount just in front of the rear tire.
When pulling the access cover off to get at the body mount bolt, that cavity was stuffed with jute. There is no other access to that cavity is there? Are these little guys using tools now?
I store mine on a lift so my wife can park underneath it in the winter. I figure if the little buggers are smart enough to crawl 6 feet in the air to nest in my frame, I'm not taken them on.....
Lee
Lee
