Go Back   Corvette Forum > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Corvettes
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations Sponsored by
Flaming River
Industries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-01-2004, 11:07 PM   #1
65air_coupe
CF Senior Member
65air_coupe's Avatar
Default Hood separated, what glue to use?
When I stripped and painted it 30 years ago, I attempted to rejoin the hood to the underside structure with 5 min epoxy. That didn't hold and now that it's apart again, I'm wondering what to use. There are some dynamite adhesives in the marine world that would work, what did GM use in the first place and has anyone had to re-bond theirs?
65air_coupe is offline   Reply With Quote
Old 07-02-2004, 08:25 AM   #2
Kid_Again
CF Senior Member
Kid_Again's Avatar
Default Re: Hood separated, what glue to use? (65air_coupe)
dynaglass that you can get from any automotive paint supply jobber
Kid_Again is offline   Reply With Quote
Old 07-02-2004, 09:24 AM   #3
wombvette
CF Senior Member
wombvette's Avatar
Default Re: Hood separated, what glue to use? (Kid_Again)
It is only bonded around the outside edge. Do not bond it on the interior edges or the cross braces.
wombvette is offline   Reply With Quote
Old 07-02-2004, 09:39 AM   #4
quahog
CF Senior Member
quahog's Avatar
i have a 66 and the hood was unbonded when i bought the car. when that project came up i used 3m 5200 its a marine adheasive that looks like the original bonding agent and holds great its been on the car for @ 2 years now no problem.
quahog is offline   Reply With Quote
Old 07-02-2004, 11:14 AM   #5
65air_coupe
CF Senior Member
Default Re: Hood separated, what glue to use? (wombvette)
I puzzled, it appears as tho it was originally bonded there and I can't imagine having those surfaces in contact without either bonding or insulating them. Otherwise, there's going to be vibration and wear. The hood obviously flexes in the center with the surface joined as well, wouldn't think that's desireable.
Old 07-02-2004, 12:44 PM   #6
Grizzly
Junior Member
Grizzly's Avatar
When I asked that question some time ago, I also got differing opinions. What I do know is there already is something there and it is not glue but more of a putty that has hardened.
The one important thing I didn't think about that was brought up is that some epoxies generate a good deal of heat when they cure and that might be bad for the paint.
I'll keep watching for a definitive answer...............
Grizzly is offline   Reply With Quote
Old 07-02-2004, 12:49 PM   #7
Kid_Again
CF Senior Member
Kid_Again's Avatar
Default Re: Hood separated, what glue to use? (Grizzly)
"I'll keep watching for a definitive answer..............."
you may be watching for a long time...all i can say is that for my cars and the midyears that i've worked on, the big block hoods have no central brace, the small blocks do, the small block braces have molded-in pads and everyone of those pads had dried adhesive between the pad and the hood - i cleaned out all of that crap and used dynaglass with great success
Old 07-02-2004, 12:51 PM   #8
65air_coupe
CF Senior Member
That's really all the answer I was looking for, thanks kid.
Update: did a little research and found dynaglass, duraglass, tigerhair, are all structural fillers, not really adhesives per se. This is a spot that can't be cleaned spotless so I think I'm going to use a true adhesive like the 3M 5200. I used it alot for maine applications and it's as permanent a bond as you can get in plastics.
[Modified by 65air_coupe, 8:17 PM 7/2/2004]
Old 07-02-2004, 03:34 PM   #9
quahog
CF Senior Member
quahog's Avatar
on where to bond. i also bonded the center section of my hood as it was originally bonded to the hood skin in the center i cleaned out the old and put 3m 5200 with no problems this is a one part adheasive that comes in a squeeze tube it does not generate heat and becomes hard but not brittle the car had new paint on it when i did this with no oll effects. no mix no fuss hardens like hockey pucks i would pay attention to the curve of the hood when you do this job as how it is clamped when drying can effect the curve i blocked the hood on its sides and put a weight in the center to press the brace and the skin together worked like a charm good luck jeff
Old 07-02-2004, 05:19 PM   #10
JohnZ
CF Senior Member
Support Corvetteforum!
Default Re: Hood separated, what glue to use? (quahog)
The inner panel cross-bracing wasn't "bonded" to the inside of the outer panel; the material you see there is a panel deadener, commonly referred to in body/paint supply shops as "gumdrops". The only actual fiberglass resin bonding material between the inner and outer hood panel is around the outer periphery of the panel.
Using aggressive resin bonding material on the cross-braces can result in "bond burn" distortion on the flat surfaces of the hood outer panel - that's why those areas weren't "bonded" to begin with.
[Modified by JohnZ, 5:20 PM 7/2/2004]
JohnZ is offline   Reply With Quote
Old 07-02-2004, 05:49 PM   #11
wombvette
CF Senior Member
wombvette's Avatar
Default Re: Hood separated, what glue to use? (JohnZ)
Thanks John for the confirmation. As usual they take no heed from knowledge and experience and follow the false prophet.
Old 07-02-2004, 06:03 PM   #12
BayRay
CF Member
JohnZ,
Where do you get the gum drop stuff??
BayRay
Happy 4th of July to all!!
BayRay is offline   Reply With Quote
Old 07-02-2004, 06:12 PM   #13
JohnZ
CF Senior Member
Default Re: Hood separated, what glue to use? (BayRay)
At any automotive body & paint supply store - just tell them you want "hood gumdrop" adhesive.
Old 07-02-2004, 06:22 PM   #14
65air_coupe
CF Senior Member
"Thanks John for the confirmation. As usual they take no heed from knowledge and experience and follow the false prophet."
Phrase it how you like, I specifically asked as to how it was done by GM. I also said it should be either bonded or insulated, the relative motion and vibration between the surfaces was/is unacceptable. Just telling me don't glue it doesn't resolve the problem.
I have no way of differentiating 'false prophets' from misinformed, do you? I suspect most of us just try to find the commonality in the sea of opinions.
[Modified by 65air_coupe, 11:22 PM 7/2/2004]
Old 07-02-2004, 06:50 PM   #15
LouieM
CF Senior Member
LouieM's Avatar
I'm told by the body shop that's working on my 67's hood that by this time nearly all midyear hoods need to have the inner hood brace re-gum dropped. Maybe so. They ground away the old gum drops, propped the hood and inner brace apart with paint stirring sticks, squirted in gum drops where the factory had originally, then removed the sticks. They repainted the inner hood. May as well do it right while the hood's off.
LouieM is offline   Reply With Quote
Old 07-02-2004, 08:11 PM   #16
65air_coupe
CF Senior Member
Default Re: Hood separated, what glue to use? (LouieM)
I think I'll follow your example and let the painters take care of before painting.
Old 07-02-2004, 10:07 PM   #17
John 65
CF Senior Member
John 65's Avatar
For what its worth, I used Liquid nails, the one that is formulated for fiberglass, says it right on the tube, and its worked great for years.
John 65 is offline   Reply With Quote
Old 07-05-2004, 12:14 PM   #18
Cmacsvette
CF Senior Member
Cmacsvette's Avatar
Well spoken.
Craig
Cmacsvette is offline   Reply With Quote
Old 07-05-2004, 03:41 PM   #19
wombvette
CF Senior Member
wombvette's Avatar
Default Re: Hood separated, what glue to use? (Cmacsvette)
Well, it was stated that y`all wanted a definitive answer and we have you one. I understand that it is hard to determine the wheat from the chaff around here, but hang around a little and you will learn.
Old 07-05-2004, 04:57 PM   #20
soppeng
CF Senior Member
soppeng's Avatar
Wombvette, what's your thoughts on using a silocone caulk for those who don't have to have it exactly as the factory, but don't want to bond the hood to the braces and risk distortion?
soppeng is offline   Reply With Quote
Reload this Page Hood separated, what glue to use?
Tags
adhesive, automotive, body, brace, bracing, corvette, fan, forum, glue, hood, hoods, pad, separated, shop, structure
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
