Strut rod replacement
OK , so what's the most efficient way to remove the old strut rods? The only advice I received so far is to soak the bolts with rustbuster.
Re: Strut rod replacement (fcabarle)
What bolts? You alking about Shock Mounts maybe. If so, The fastest an easiest method I use without fail is an air hammer. I use the air hammer wiht a large pickle fork on it, hold it up against the 90 degree angle after the shock is removed and the bolt from the backside is removed. Couple pulls of the trigger and they are out without damaging any threads. Takes about 3 seconds.
1 Post
Re: Strut rod replacement (78Vette-SA)
We ha a hell of a badly rusted screw within a 76 that we did some weeks ago....never had seen a broken (!) strut rod whilst driving before....
Since there was no time to wait for any rust to come off this was a WD40 and brute force event. Took us about 1,5 hours for the one thing.
I you have got some more time you may as well test coke....as this pretty much eats rust. Don`t know if it really would crawl to the inside...
they can be a bear to get out....... i don't know if you're on a budget, but if you ruin anything let me know, i just put all new components on my '66, and the old ones are still useable
If it seems really frozen and the sugested methodes don't go well. Use
a cut off tool on it. If you break the bracket it will cost a lot more in
parts and labor
parts and labor
