GMPP ZZ454CI/440 Crate BB Motor Question ..Ok Motor Heads Your Up..!!
Getting raedy for the BB Conversion using the ZZ454CI/440. The GMPP Web Site tech sheet see below... Recomends a 850 CFM Carb. Now Holly makes an 850 I know..but I'm not a big fan of Holly's.. I'm a Carter fan.. Here's a link to Edelbrock showing there new series AVS...
...Select Carbs from the Left menue and then Thunder Series AVS 800CFM
http://www.edelbrock.com/automotive/index.html
The biggest they make is an 800 CFM. Now...using the formula from Holly's site
Engine size (CID) x maximum RPM / 3456 = CFM
CFM @ 100% volumetric efficiency
(Example: 350 CID x 6000 RPM = 2,100,000 / 3456 = 608 CFM)
Approximately 608 CFM would be required for this engine. However, most Street engines are capable of achieving only about 80% VE; a modified street engine with ported heads, headers, intake and carburetor can achieve about 85% VE; a fully modified race engine can achieve 95% or greater VE. The CFM number arrived at with this formula must be factored by this percentage.
I figured out that @ 6000 RPM I am good to go with a 800CFM. I don't plan on draging the car just cruzing it and Floging it every now and then. So what do you think?? SWC Duke...John Z and all our other Motor guys what's you thoughts?
GMPP ZZ454CI/440 HP Web Page Below http://www.gmpartsdepot.com/store/pr...roduct_ID=1805
:cheers:
Sorry for all the edits but my wireless mouse is freaking out..had to change batteries.
[Modified by Viet Nam Vett, 6:19 PM 4/11/2004]
[Modified by Viet Nam Vett, 6:20 PM 4/11/2004]
[Modified by Viet Nam Vett, 6:25 PM 4/11/2004]
:cheers:
12.14 w/ the original 327
Re: GMPP ZZ454CI/440 Crate BB Motor Question ..Ok Motor Heads Your Up..!! (Viet Nam Vett)
Big Blocks are pretty forgiving on carb choices. If you're not gonna be racing, I'd run the smallest carb to meet your engine's needs. You'd probably be fine with a 750, 800 or 850 carb. I know you didn't ask, but Holley makes a vacuum secondary 850 carb that would be nice on the street. Any of the above could be made to run nicely on your 454.
You mentioned you like Edelbrock carbs. I ran an 850 Edelrock Q-Jet on a Caddy 500 and loved it. The throttle response and mileage were great (OK, mileage in a 500 Caddy is a relative term). I'll be running the 850 Q-Jet on my Chevelle's 496 when I fire it up in a couple weeks. Good luck with the swap.
Wes
Wes
based on your intended use, and the fact that we're talking about a 440HP 454, I'd go with a 780 vac secondary holley (sorry but i'm a holley guy), it'd be about perfect....they really are great carbs, and if you get a GM-type repo the choke would hook right up to your intake (no need for some electric choke rig), you could use a midyear vette air cleaner, etc., it's just a matter of trying different secondary springs to get it just right for you/your gearing.
i don't think the std Edelbrocks come bigger than 750 (which might be ok for you.... i think they made ~540 HP with one on a 454, see their website/dyno results), and they do have a "EPS 800" (800 cfm)......... but again, why not go with what a midyear BB is suppose to have ? a dual feed holley :-)
[Modified by 66427-450, 7:46 PM 4/11/2004]
Re: GMPP ZZ454CI/440 Crate BB Motor Question ..Ok Motor Heads Your Up..!! (66427-450)
Doesn't it seem from Lar's testing that the BG Speed Demon 850 would be the best of your choices?? Dave..
I'm sure not all Holly's leak and I know the are used by many a professional and ammature racers and have a good track record. But when you look at the simplicity of the Carter design and the Jet adjustment and the Fuel Bowl design you gotta give it a good look. I've been running Edlelbrock (Carter) Dual 4's on the 65 for the last 6 years with not a boil over or a leake or jet problem. The secondaries have always opened with nery a problem. To me it is a reliable carb.
Your suggestion as far as CFM sounds good..don't want to over CFM the Motor.
:cheers:
Re: GMPP ZZ454CI/440 Crate BB Motor Question ..Ok Motor Heads Your Up..!! (youwish2bme)
Yeh The Lars Special I,m sure it's a great carb. But I'm not a fan of those fule bowls that hang in mid air. 850 CFM I think is a little to big for my application. Don't want a Bog monster off the line... :lol: :cheers:
Re: GMPP ZZ454CI/440 Crate BB Motor Question ..Ok Motor Heads Your Up..!! (wesmigletz)
Wes
Wes
Yep I had me a few of them there Q Jet's... Great Carb..!! But the New Edelbrock Carter type seems better to me.. :cheers:
well if they (edelbrock) made 540HP with it (a 750CFM carter copy), it should be all you need for that 440 HP crate motor.
St. Jude Donor '03 & '05
If you're not constantly making performance mods and tuning for peak performance, I don't think it really matters what brand you go with. I ran a Q-Jet on a big block for awhile and had no problems. I also ran a 750 Holley and it was enough CFM for street use.
C2 of Year Finalist (stock) 2019
Man -- I cant believe you are going to do this -- however good luck. This is a major undertaking in my opinion. I know you are more than capable of doing the work -- it is just why ????
Are we going to do this in Denney's new garage ?????
I know you said you don't like Demon carbs but you might want to check this out anyway. I think they're the best carb out there. http://forums.corvetteforum.com/zerothread?id=790972
Re: GMPP ZZ454CI/440 Crate BB Motor Question ..Ok Motor Heads Your Up..!! (JL66REDCPE)
BB's are fun..Low end Torque is Fun..Blowing Off riser's is fun...and hanging out here and getting info on a planned upgrade is fun. Shelling out money is not fun. But smoking the tires makes up for the shelling out thing.
And the number 1 reason is......Putting in a BB motor is a lot cheaper then buying a Complete BB car.
The front end in my rat needs a rebuild anyway...so I can upgrade to BB springs and parts while it's apart. So..I'll enjoy the summer and start this fall.
Denney's place is to far to go...besides he doesn't know the difference between a "EGR Valve" and A "PVC Valve" :lol:
We will pull the old motor at Rob's Place then trailer the car back here and rip out the front end .. then back to robs for he new motor drop in. Then back here for finishing the rest.. I'll give you a call when we get started we could use your help.. :cheers:
How about another idea.
I have an L 88 top end on my 68.
http://www.sirgalahad.org/tyler/misc...ompartment.jpg
But love the look of the old hilborn mech fi but they are a pain to get right on the street. But in the last year of so there is a group of people who have designed a DIY EFI that can be had for $120 and used to control fuel only. SO started watching ebay and found an old 427 hilborn unit for $400.(Which is cheaper than a good aftermarket EFI manifold)
http://www.sirgalahad.org/tyler/misc/427_intake.jpg
Which I plan on putting efi injectors in in the next few weeks. Then I try out my soldering skills with:
http://www.bgsoflex.com/megasquirt.html
I also have a 61 that I plan on doing the same thing with. I love those old Hilborn, Kinsler units and with the DIY efi control one can have both worlds.
If you ever wanted to know about converting an old car to EFI this is the site to start with. You may not end up using this unit but you will sure learn a thing or two. In development is a unit that uses a WB O2 for info ALL the time WOT and closed loop. The test vehicle is a chev 350.
Here is a original Kinsler unit (S/N 3 earliest Kinsler unit known to exist) on a 58 Lister Chev. note the base is a early Rochester FI unit.
http://www.sirgalahad.org/tyler/misc/kinsler_3.jpg
Tyler
Tyler
Re: GMPP ZZ454CI/440 Crate BB Motor Question ..Ok Motor Heads Your Up..!! (Brutal64)
That was some fine reading.. That Lars is da man.. My use for this car is just cruzing.. I'm not into super tuning this thing just road cruzing and flogging it every now and then. I just want a nice idol..good acceleration and smooth cruzing at highway speeds.
To bad Lar's isn't in my area..I definitley would get him involved in this project. :thumbs:
Quote*
six-T-six
Quote*
Six-T-Six
So I should be in the Ball Park with an 800CFM.. :thumbs:
six-T-six
Quote*
Six-T-Six
Re: GMPP ZZ454CI/440 Crate BB Motor Question ..Ok Motor Heads Your Up..!! (Tyler Townsley)
Heh Tyler,
Man that is cool....That would be a fun project for crazzies like us. Definitly would be the coolest Car at a Vett show. :thumbs:
But..I'm staying with a carb. My 86 is EFI and the 65 is my get a way from the new tech age...But I would like to see pic's as you progress on this project. Keep us posted.. :cheers:
1 Post
Hey Mark - Been busy with tax season or would have replied sooner. My 66 was originally a small block. When I took it off the road in 1984 - yeah 1984 - I decided to do the big block thing. Did it all up to look original. Still have all the small block stuff up in the garage loft, except the drive train - that is stashed under the work bench for another day.
Build it the way you want, spend lots of money and have a blast!!!
Call or e-mail when you get started. I can schedule some time to give you a hand.
Mark -- just let me know when.
john
john
Check out GregP, he's doing what you're talking about with the old style injector manifold on his car.
Re: GMPP ZZ454CI/440 Crate BB Motor Question ..Ok Motor Heads Your Up..!! (4WDVETTE)
Heh Steve..Your ON....!!! I will defenitly call you when I get ready.. :thumbs:
