4sp bell houseing
Old 12-24-2003, 03:21 PM
BILL88
BILL88's Avatar
Default 4sp bell houseing
changeing from auto to 4sp, 1966 corvette whith a 1975 350 truck block/motor, 425 hp
two questions,
can i use the same starter,
which bell housing, (numbers)
thanks much,
bill
Old 12-24-2003, 06:39 PM
yooperod
yooperod's Avatar
Default Re: 4sp bell houseing (BILL88)
the stock 10.5" bellhousing and flywheel fits (old)gm almost forever (very common unless you want certain date or number)
IE 67-81 camaro, i have the complete interchange if you want
not sure about starter (because of your '75)
if you go with the 11" (has a bulge on the side for starter)
the starter is different and of coarse the fly dia.
hope this help some
rod
Old 12-26-2003, 01:56 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,856 Likes on 1,099 Posts
'64-'72 SB's used bellhousing casting #3858403, with a 10.5" clutch and a 153-tooth flywheel. :thumbs:
To 4sp bell houseing
Quick Reply: 4sp bell houseing
