POLERIZING MY GENERATOR AND VOLTAGE REGULATOR
Old 09-27-2003, 11:21 PM
STEVES59
STEVES59's Avatar
Default POLERIZING MY GENERATOR AND VOLTAGE REGULATOR
SOME ONE PLEASE SPLAIN TO ME :banghead:
Old 09-28-2003, 12:57 AM
Chuck Gongloff
Support Corvetteforum!
Chuck Gongloff's Avatar
Default Re: POLERIZING MY GENERATOR AND VOLTAGE REGULATOR (STEVES59)
In order for the generator to charge, the armature has to have the correct polarity in respect to the field coils. SO....you take a wire and "spark" the armature terminal from the POS battery terminal. That gives the generator the correct polarity. If you don't spark or polarize it, it won't charge. Chuck
Old 09-28-2003, 01:08 AM
K2
K2's Avatar
Ok here goes. Its a very simple procedure. After installing the generator and hooking up all of the leads, but before starting, it is necessary to polarize the generator. The polarizing procedure is different depending on whether the field is internally or externally grounded. Since I'm assuming you are working on a C1 I know that the generator is of the externally grounded variety and the following procedure should be followed. Get yourself a jumper wire and momentarily connect the jumper from the Bat. to the Gen. or Arm. terminal on the voltage regulator. Just a momentary contact (1/2 second) is required. That's all there is to it. :smash: :steering:
Old 09-30-2003, 07:42 AM
Jimbo64
Jimbo64's Avatar
St. Jude Donor '09
I just replaced the alternator on my 64 but did not polarize it. It appears to work fine but is this something that I needed to do and should always do if alternators are changed? Is the procedure the same. thanks -----Jim :seeya
Old 09-30-2003, 08:02 AM
Tom/99
Tom/99's Avatar
Default Re: POLERIZING MY GENERATOR AND VOLTAGE REGULATOR (Jimbo64)
Jimbo64, You do not have to polorize an alternator, just a generator.
Old 09-30-2003, 08:14 AM
Jimbo64
Jimbo64's Avatar
St. Jude Donor '09
Default Re: POLERIZING MY GENERATOR AND VOLTAGE REGULATOR (Tom/99)
Tom thanks for the quick reply. With me, each bit of information is an educational
thing as I'm learning. Guess that will go on as long as I tinker. Have a great day> :cheers:
Old 09-30-2003, 10:59 PM
62fuelie
62fuelie's Avatar
If you don't polarize the generator, there is a 50/50 chance it will work correctly anyway. It's a good idea to follow the proceedure any time any of the components in the charging system are changed or disconnected.
Old 04-21-2011, 08:07 AM
1959VetteJan
1959VetteJan's Avatar
Folks,
I will be putting in a rebuilt generator into my '59 Vette. Just wnat to ensure that I don't mess up the polarizing of the gen. The jumper cable would be connected to the positive pole on the battery to which of the three on the generator? I am assuming that the one on the top is the correct one (the one with the round warning tag).
Please confirm before I cause more damage :-)
Thanks,
Jan
Old 04-21-2011, 09:58 AM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
You can do it with a short jumper right at the voltage regulator -- these are the instructions (in the red stripe at the top) right off the regulator.
Old 04-21-2011, 10:23 AM
Donald #31176
Donald #31176's Avatar
http://www.johnpirkle.com/tech%20tips/tech%20tips.htm
Old 04-21-2011, 05:33 PM
leaky4150
leaky4150's Avatar
when replacing a voltage regulator. does the regulator need to be polarized with an alternator in system?
Old 04-21-2011, 05:40 PM
Frankie the Fink
Army
You polarize the GENERATOR not the REGULATOR so, no, if you have an alternator -- no polarization required...
Its a big confusing since you can polarize the generator at the V/R terminals...
Old 04-21-2011, 06:24 PM
John S 1961
John S 1961's Avatar
I like to polarize a generator by tossing it in the nearest large body of water, If it floats back up its polarized and good to go.
If it doesnt I install an alternator and never worry again.
Old 04-21-2011, 07:06 PM
Frankie the Fink
Army
I never worry with my generator....never had it off the car; never had to touch it yet....
and it runs my 600W Kenwood radio amplifier just fine...
Old 04-21-2011, 07:39 PM
1snake
1snake's Avatar
You're right. Generators suk and are a maintenance nightmare. In fact, I've actually had to replace the brushes in mine, ONCE IN 35 YEARS. My suggestion is, tie 1000 generators to your body and jump in that same body of water. If you float back up, you're NOT an idiot. There are millions of cars running generators that have zero problems.
Jim
Old 04-21-2011, 08:25 PM
Pilot Dan
Pilot Dan's Avatar
Rebuilt my original generator once 20 + years ago and never had to touch it since. As for polarizing, key on, small flat blade screw driver across the two terminals of the regulator momentarily and your done. Those without training as a rocket scientist need not worry. Pilot Dan
Old 04-21-2011, 08:28 PM
Ironcross
Ironcross's Avatar
To POLERIZING MY GENERATOR AND VOLTAGE REGULATOR
Quick Reply: POLERIZING MY GENERATOR AND VOLTAGE REGULATOR
