Go Back   Corvette Forum > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Corvettes
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations Sponsored by
Flaming River
Industries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-06-2003, 08:01 PM   #1
Old Vetter
Junior Member
Default backspacing on 15x7 rally wheel
Can someone please tell me the backspace on original 68 15x7 rally wheels? I want to put a set on my 66. Also are the 68 to 82 trim rings the same depth? Thanks
Old Vetter is offline   Reply With Quote
Old 08-06-2003, 08:38 PM   #2
vettes1st
CF Senior Member
St. Jude Donor '06
Default Re: backspacing on 15x7 rally wheel (Old Vetter)
Trim rings are all the same. I don't have a wheel handy.
vettes1st is offline   Reply With Quote
Old 08-06-2003, 09:09 PM   #3
nitram
CF Senior Member
nitram's Avatar
I have a set of 15x7 corvette rally wheels that are stamped AG. I'm not sure what year they are, but they have 3 1/2" backspacing. Hope this helps, Byron
nitram is offline   Reply With Quote
Old 08-06-2003, 09:18 PM   #4
joevette57
CF Senior Member
joevette57's Avatar
Send a message via AIM to joevette57
Default Re: backspacing on 15x7 rally wheel (nitram)
I had a set of 15x7 Vette rallys I test fit on my 66. I didn't like how close they came to the rear fender lips. (with 205/75-15 tires). A 3.5 " offset gives you 3.5 towards the lip compared to 3.0 with standard 6" rallys.
There are some 15x7 rallys that were specific to 69 z-28 Camaros that had 4.0 backspacing which gives you the proper distance to the fender lip. 4" backspace is about the best you can do without having interference to the e-brake clips on the trailing arms.
joevette57 is offline   Reply With Quote
Old 08-06-2003, 10:07 PM   #5
SWCDuke
CF Senior Member
Default Re: backspacing on 15x7 rally wheel (joevette57)
I don't deal in backspacing, but their offset is -0.28". Beware that other Chevrolet seven inch Rallys used on other models have different offset. Because of their negative offset you can't put on a tire that justifies a seven inch wheel without shaving the horizontal fender lips on a C2.
The six inch Rallys have +0.60" offset and with a 215/70R-15 tire will normally have sufficient clearance to not hit the fenders. Setting front camber at zero to a bit negative and rear camber at at least -0.5 degrees should give more than adequate clearance. The only other issue might be front frame rubbing at maximum steering lock, but since you probably won't be at maximum lock above parking lot speed, it's not a big deal.
Duke
SWCDuke is offline   Reply With Quote
Old 08-07-2003, 08:55 AM   #6
Old Vetter
Junior Member
Default Re: backspacing on 15x7 rally wheel (vettes1st)
Thanks for all the info. I've noticed that there are rally wheels with different back-spacing. I thought that I could get a 15x7 rally with a 4" back-space but I was concerned that a standard 68 trim ring would not fit. I measured the back-space on my knock-offs and they were 4"
Old 08-07-2003, 12:55 PM   #7
66427-450
CF Senior Member
66427-450's Avatar
Send a message via AIM to 66427-450
68 vette = AG
-.3 offset
backspace ~ 3.5"
Monte/Z-28 = YH or FW
+.3 offset
backspace ~ 4"
Monte/Z ~.5" farther away from the lip, but closer to the rear spring
[Modified by 66427-450, 12:56 PM 8/7/2003]
66427-450 is offline   Reply With Quote
Old 08-07-2003, 01:02 PM   #8
TheOman
CF Senior Member
Default Re: backspacing on 15x7 rally wheel (66427-450)
15 x 7 's off a Monte Carlo will hit the brake cable brackets, the tire sidewall may rub the brake cable and the outside of the rim will hit the end of the spring. Believe me I know. If you jack the car up to allow full extension of the suspension and try turning the wheels the wheel weights and I think the rim itself WILL hit the end of the spring. On the road it is OK. On the front 15 x 7 will rub the frame behind the front suspension. The bolts that hold the steering box in place take a nice polish from the sidewall.
TheOman is offline   Reply With Quote
Old 08-07-2003, 02:40 PM   #9
66427-450
CF Senior Member
66427-450's Avatar
Default Re: backspacing on 15x7 rally wheel (TheOman)
Duke -
Don't/didn't, you run 7" vette rally's and 225/70's on your '63? Seems like I remember you saying that.......
Old 08-07-2003, 06:08 PM   #10
toddalin
CF Senior Member
I run the 32-spoke Western Wheel Turbine wheels with center spinners (the look of Corvette knockoffs at a small fraction of the cost). They are 7 inches wide with 3-3/4" backspacing and fit my '64 perfectly with 225/60/15 tires. (They were used on Z-28 Camaros but mine are for Chevy/Ford/Chrysler with "slotted" lug holes.) I need to use a thin wheel spacer in front to clear the cailpers on the disks and even then, I can wipe the steering box carrage bolt shiny on a locked left turn.
toddalin is offline   Reply With Quote
Old 08-07-2003, 07:55 PM   #11
SWCDuke
CF Senior Member
Quote:
Duke -
Yeah, but I had to trim the horizontal fender lips and front bonding strip. I did this back in 1968!!!, but I DO NOT recommend that folks do this today. I'm the original owner, and I doubt if I'll ever sell it unless they pry my driver's license away from me went I get senile, and I probably won't sell it even then - just park it in my living room.
I do have to admit that 225/70VR-15s on '68 seven inch Rallys look (and work) great. The wheel cover "Ben Hur" spinners stick out beyond the bodywork and can take out the kneecaps of daring pedestrians who stand on the curb if I clip the apex real tight. ;) The big wheels and tires really give it a hunkered down appearance.
Duke
Old 08-07-2003, 09:15 PM   #12
66427-450
CF Senior Member
66427-450's Avatar
Default Re: backspacing on 15x7 rally wheel (SWCDuke)
Yes, that was a popular mod way back then, lol...... I did the same thing to my '64, in about '73, when I was playing around with NCCC and SCCA autocross.
My '66 has had that done to it as well (front and rear)....... the guy did a really nice job, unless you knew what to look for, you'd think it was factory.
:seeya
PS: Same here on re my '66, not for any price...... I'd make them bury me in it, but I want the old beast to live on.
Old 08-08-2003, 01:53 PM   #13
STING67RAY
CF Senior Member
Support Corvetteforum!
at one time i purchased a pair of rallys 15x7" from summit.
ordered a backspace of 4" these work well. i ran a 225/70x15 white wall.
one side is close and on hard bumps it rubs.
i recently upgraded to tork thrusts. custom part number CL205.
in 15x7 with 4" b/s all around. i am using 225/60x15.
still close on the same side. may be just my car. but other than that they look fine. no other rubbing that i can tell.(autocrossed twice now).
rubbing is on drivers rear. if i went with a 215 or 205 i'm sure it would be fine. but since there is no serious rubbing, i'll stick with 225.
d.s. in n.j.
STING67RAY is offline   Reply With Quote
Old 08-09-2003, 08:19 PM   #14
Old Vetter
Junior Member
Default Re: backspacing on 15x7 rally wheel (STING67RAY)
I just ordered a set of rallys from Newstalgia. I ordered 15X7 with a 4" backspace. I'll let you know later how they work out. Thanks for the answers.
Old 08-12-2003, 11:29 AM   #15
66427-450
CF Senior Member
66427-450's Avatar
interesting...... do these repo's look the same? i've seen some that were configured significantly different in the lug nut area..... not true repos at all.
Reload this Page backspacing on 15x7 rally wheel
Tags
15, 1968, 4, 63, 66, back, backspace, backspacing, corvette, fw, maximum, mid, rally, spacing, wheel, wheels, year
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Rally wheel questions goinbroke C3 Tech/Performance 9 03-29-2003 04:31 PM
Will 15" X 7"s fit on a midyear??? Brian Matheis C1 & C2 Corvettes 17 11-28-2002 08:26 PM
Are these tires going to work?? bondo478 C1 & C2 Corvettes 9 01-14-2002 11:47 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
