63 Sw Coupe Value?
63 Sw Coupe Value?
You guys have been around this so much, I need your advice. I found a near mint 63. It has had Vintage air added on. Does this addition devalue the car or was it altered in any way that could not be returned to original?
Thanks for the help. :confused:
Re: 63 Sw Coupe Value? (Bigb69)
It depends on what your buying the car for. If the car is going to be a driver then "no" its not going to detract from the value, and it may infact add value to the car. If the car is purchased as a Trailer Queen and only for shows, then yes having the Vintage Air would detract, because it is not origional equipment. For the most part it can be removed and not have any tell tale signs that it was ever installed.... :smash: Good Luck..... :cheers:
