What are recomendations for fluid >>Muncie 4 speed ,66 big/block
Draind trans fliud from my 4 speed, (1966 big/block) I drilled a 9/16'' hole in boss on side of transmission , drined fluid & tapped & installed drain fitting plug, .. :smash: thinking of going with a synthetic :confused: any suggestions............... :seeya :steering: :auto: :flag
Received 1,973 Likes
Re: What are recomendations for fluid >>Muncie 4 speed ,66 big/block (StrayDog)
The OEM spec is MIL-L-2105. This is the same as current API 80W-90 GL5 gear oil. You can buy this in mineral or synthetic base, but be sure you buy a brand that DOES NOT have the limited slip friction modifier. Most don't, but Redline, for example, offers both. The one you want for the transmission is called "75W-90 NS gear oil". Their " 75W-90 gear oil" DOES have the limited slip friction modifier additive.
I don't think synthetic will buy you much, especially if you don't drive the car in cold weather. I would recommend standard mineral oil based GL-5 and change it every 30K miles, or more often if you are hard on the transmission. Periodic manual transmission fluid changes will flush out most of the tiny brass particles that inevitably build up due to synchonizer wear.
Duke
Duke
Re: What are recomendations for fluid >>Muncie 4 speed ,66 big/block (SWCDuke)
Duke,
I was under the impression that GL4 was better suited to transmissions and GL5 for rear ends(but can also be used in transmissions). Am I misinformed?
Duke>>>>In my situation , I do drive in cold weather ( or much colder than west coast/Calif)in the fall / spring, many short drives (20 miles)in 40 deg weather.............So I want to go with new tech on trans fluid( I use Moble one 10/30 ) in my 427, & very satisfied ............... The Dog (cold dog) :crazy: :steering: :auto: :flag
Re: What are recomendations for fluid >>Muncie 4 speed ,66 big/block (JoesC5)
Duke,
GL-5s have extreme pressure additives than modern synchronizers don't like. Synchronizers need some friction to operate properly, and GL-5s can be "too slippery" for them, but GL-5 is the recommended lubricant for our vintage three and four speed manual transmissions.
What would be the effect of running a GL-4? I don't know. I've never tried it. There may or may not be a noticeable change in synchro action, and any long term effects would require a disciplined long term test, which most of use aren't set up to do.
The C5 is generally known as having a "transaxle" but that is a misnomer. The transmission and axle are bolted together, but have separate housings and lubricant supplies. I think the six-speed manual lubricant is ATF and the axle uses a GL-5. Transaxles that combine both a manual synchronized transmission with a hypoid gearset are problematic when it comes to lubricants due to the different and often conflicting requirements of synchronizers and hypoid gearsets. Porsches, Audis, and the ZF transaxles used in the vintage GT-40 and Pantera come to mind, and GT-40 and Pantera owners are advised to use the special transaxle lubricant sold by Porsche/Audi dealers.
Duke
I was having problems with my Muncie. Put Redline NS in after draining it completely. The drained fluid was very black and had a lot of small brass particles. Runs like new....very smooth. Actually easier than my C5.
Re: What are recomendations for fluid >>Muncie 4 speed ,66 big/block (hot1corvette1)
I run synthetic oil in my muncie with no problems. :seeya
I use the old 80-90W mineral based gear oil, and the Muncie will stand all the power shifts that I can throw at it.
Do any of the 4 speeds with other than 80-90W mineral based gear oil leak?
:skep:
:skep:
Received 1,856 Likes
Re: What are recomendations for fluid >>Muncie 4 speed ,66 big/block (magicv8)
I guess I'm just an old-fashioned engineer - I run GM diff lube and GM Posi additive in my diffs, and good old 80W-90W gear lube in my Muncies, and have in many cars over many years, never had a problem (or a leak). :thumbs:
