Go Back   Corvette Forum > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Corvettes
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations Sponsored by
Flaming River
Industries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-16-2003, 09:49 AM   #1
JL66REDCPE
CF Senior Member
JL66REDCPE's Avatar
Send a message via AIM to JL66REDCPE
Default Big Block Oil Leak
I uncovered the car and did some test runs yesterday. I noticed a drop and stream of oil on the top of my exhaust manifold at approx #4 cylinder. I ran my hand under the valve cover looking for oil and found none. I wonder if it could be coming out of the dipstick. I recently changed the dipstick and dipstick tube. There is a rubber boot on the dipstick and it seems to fit ok over the tube. I didnt think there was any pressure built up in the oil pan. Unless the PCV valve is not working which I will check today. Anyone have any other ideas on where to check.
thanks
john lolli
JL66REDCPE is offline   Reply With Quote
Old 03-16-2003, 11:12 AM   #2
396 RAT
CF Senior Member
396 RAT's Avatar
Default Re: Big Block Oil Leak (JL66REDCPE)
:confused:
I do know 1st hand the valve covers can play tricks on you
concerning leaks.....
But on top of the intake? Hmmmm.....
I would double check the covers......
Can also look just like a rear main seal, those thin pesky covers.
396 RAT is offline   Reply With Quote
Old 03-16-2003, 12:35 PM   #3
JL66REDCPE
CF Senior Member
JL66REDCPE's Avatar
Default Re: Big Block Oil Leak (396 RAT)
Rat
The oil is on the top of the Exhaust Manifold.
john lolli
Old 03-16-2003, 05:41 PM   #4
396 RAT
CF Senior Member
396 RAT's Avatar
oops :bb
I would still look at the valve covers cross eyed......
Old 03-16-2003, 08:49 PM   #5
Kid_Again
CF Senior Member
Kid_Again's Avatar
hey john...bummer.....never heard of oil shooting out of the dip stick tube, and you're right, the oil pressure is downstream from the oil pump, not in the pan...did you do anything else to the car that might be the cause?
Kid_Again is offline   Reply With Quote
Old 03-17-2003, 07:30 AM   #6
JL66REDCPE
CF Senior Member
JL66REDCPE's Avatar
Default Re: Big Block Oil Leak (Kid_Again)
Kid - I installed a new dipstick, dipstick tube and oill fill cap. I didnt do anything else on that side of the engine. This one os quite a mystery. I am going to run the car and re-check the underside of the valve cover. The oil was laying just below where the top of the exhaust manifold mates with the block.
Old 03-17-2003, 12:19 PM   #7
SWCDuke
CF Senior Member
Anything on the valve cover adjacent to #4 - like the oil fill cap or a PCV connection? If so, that's were I'd start. The oil could be leaking down the cover and accumulating on the bottom flange before dripping onto the manifold. Maybe your new oil fill cap is not sealing properly to the valve cover.
Whenever something happens always ask yourself: What's the last thing I did? In this case it sounds like you changed your oil fill cap, and it may be the culprit even though it is new.
Duke
SWCDuke is offline   Reply With Quote
Old 03-26-2003, 08:02 AM   #8
JL66REDCPE
CF Senior Member
JL66REDCPE's Avatar
Well it appears that the manifold bolts (top bolt left of #4 and lower bolt right of #6) are probably loose. What I thought was oil seems to be a raw gas mixture. There was a kind of spray pattern just above the manifold where it meets the block. Funny, I didnt hear an exhaust leak but there is no doubt that is what it is. I hope the gasket is still ok. Going to try and tighten/re-torque the bolts and see what happens.
Old 03-26-2003, 08:58 AM   #9
396 RAT
CF Senior Member
396 RAT's Avatar
:thumbs:
Old 03-27-2003, 05:38 AM   #10
Kid_Again
CF Senior Member
Kid_Again's Avatar
john...did you get my email?
Old 03-27-2003, 09:23 AM   #11
JL66REDCPE
CF Senior Member
JL66REDCPE's Avatar
joe -- you have mail
Reload this Page Big Block Oil Leak
Tags
396, big, block, burning, cover, dipstick, gas, leak, leaking, leaks, main, oil, rear, seal, valve
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
