Throw out bearing replacement
You have to remove the transmission. At least pull it back enough for the shaft to come out of the throw out bearing. If you are changing out the throwout bearing, it would be best to change the whole clutch in most cases. Not an easy job at all due to welded crossmember. It's basically a full clutch job to change the throw out bearing.
The transmission needs to be pushed all the way back over the crossmember and shifted to get the pilot tip off to the edge off the bell housing opening and you should have enough room to change it out.
Couple thoughts. Mine is 67 and I did not have to drop trans to floor, or remove bell housing. That in my opinion makes it much easier than clutch. Second, why did it fail? Often it is because it wasn't mounted on fork properly. Look for pics that show how it slides on to the fork with the flat metal retainer spring still in contact with the fork. Not with the lip of the bearing between the spring and the fork. Good luck with it.
Jay
Jay
Thank you SJW I did not have that illustration. I am pretty sure I installed it wrong. Now if I can just fix it without having to take everything back apart.
Jay
Jay
