[C2] Carburetor leak
Carburetor leak
Not a week into inheriting my Dads 67 I need some help.
The Holley carb is spewing gas out of oue front bowl at the "weep" valve on top as she warms up. I just finished a sniper 2 install on my 68 L78 Camaro, and am thinking of investing for the same setup on Dad's.
Any ideas? Easy fix maybe?
67 vette, 68 camaro
67 vette, 68 camaro
Received 6,986 Likes
2015 C2 of Year Finalist
stuck float?
The following 2 users liked this post by Nowhere Man:
leif.anderson93 (04-21-2024),
warrenmj (04-21-2024)
Received 2,144 Likes
2015 C2 of the Year Finalist
67 vette, 68 camaro
67 vette, 68 camaro
Dan
1967 Pedal Car Champion
If it continues, the front bowl removes easily with just the 4 corner screws. Clean it out with carb spray, work the float up and down as you do this. Check the float height setting and reassemble with Holley's reusable gasket.
Give the top of the float adjustment screws a few wraps with a screwdriver handle. When a Holley is shut down hot and not driven again for some time the floats can stick to the varnish left behind from evaporating hot gasoline. When you start a car cold with this condition it will run lumpy and pig rich. Shut it down. Give the carb some sharp raps as above and that should cure it. I go through this same BS with my L78/Holley every spring.
Dan
Dan
I kepted a spare needle/seat, along with a points/condenser set in my glove box:-), upgraded to Rochester F.I. got rid of the needle/seat in glove but replaced it with a spare drive cable for the dist. To gear driven F.I. fuel pump🤒, never ends..
Chalie
It could be a leaking needle and seat assembly. Not uncommon in last several years.
Dan
Dan
67vetteal (04-21-2024)
