where to connect the spark plug wire grounding holes at the distibutor
does anyone have an image of where to connect the metal holes at the distributor end of the car here is an image attached
Received 6,986 Likes
2015 C2 of Year Finalist
In the igniting shielding there are a threaded post on each side that four of lugs go on then a little nut Your learn a few new words doing that
Tether Man
Received 2,027 Likes
2019 C1 of Year Finalist (appearance mods)
Terminations for the grounds are group terminated inside the shielding housing (4 grounds per side) under the cover that houses the distributor! It can get a little tight getting to the distributor to set timing. My (NO RADIO) 67 does not have this setup!
See your Assembly Manual, section U69, sheet A11.
Go Here:
Go Here:
Hard to see in this picture but I gather the 4 leads up from the plug wires and include a homemade lead with an eyelet terminal on one end and an alligator clip on the other end. The 4 plug wire leads and the extension are secured together with a small screw and nut and the alligator clip fastens to the stud on the side shielding supports. That way I just have to fasten the alligator clip on the stud instead of fooling with 4 spark plug wire leads and a nut.
dcamick (04-17-2024)
1967 Pedal Car Champion
Here are the spark plug wire brackets on each side of the distributor for 427s. The threaded studs are where the braided end-eyes are attached. The other spark plug ends are attached in pairs to specific valve cover bolts. Can't recall exactly which bolts on which side but I'm sure others can post pics.
