[C2] GF-90 fuel filter fittings
Received 6,547 Likes
C2 of Year Finalist (track prepared) 2019
Inlet is 5/16 Inverted Flare. Outlet is 1/8" NPS.
Are you wanting to make your own fuel lines? If so, any FLAPS can get you the right fittings if you tell them the above mentioned sizes.
Thank you for your quick reply. On my filter they are both the same size. I've seen brass 90' used .
