Vin help
Cruising
VIN serial help
Hey everyone! My first post as I have been searching through the forums and need help. I’m looking at a 65 convertible and the vin serial doesn’t add up. Any thoughts or help?
the rivets look wrong and there's a 'bolt/screw' holding the trim tag on...is this whats not adding up?
am6174uh (03-26-2024)
Cruising
Cruising
Received 1,922 Likes
Yea....the sequence number doesn't add up. Should be between 100001 – 123564.
What does the VIN say on the title? Maybe someone else can provide more insight.
I would definitely tread lightly on this one. Just want to be sure all is legit.
Pat
Pat
Cruising
Andrew - As the other guys have already pointed out, as you did too, that VIN is way off. These days, folks can buy aftermarket VIN and Trim Tags and they ones you posted look very odd.
By the way, welcome to the Corvette Forum. Not sure where you are located in Arizona but if close enough, hopefully you'll have the time to come up to the Annual Prescott Corvette Show.
Back to the 65 you're looking at, can you post up any more pics for us to decipher?
Mike T - Prescott AZ
There were a little over 23K made...
Cruising
as for the car all add these photos and see what everyone thinks
Cruising
The dash has screws holding them it on instead of rivets...the door 'lock' area has exposed rivets that are wrong all wrong..
1967 Pedal Car Champion
If we assume the VIN is 194675S100596, this places the car in the first week of production. Cars up to about 7700 used round rivets after which the transition to rosette rivets began.
Hopefully it's got the original engine... what does the engine stamp VIN look like?
Does it have the Protect-o-plate in the owner's book?
The transmission should (?) also have the partial VIN beginning with the "S".
What does the frame stamp look like?
I'm curious about these alternate VIN stampings.
Cruising
Addendum:
New pics posted while I was composing my reply above. I'd steer far and clear of this car. Even giving the benefit of the doubt on the VIN tag being human error, there are too many other weird things, most of all, the '64 interior. Those gauges and the textured dash/waterfall are not '65. The gauges should be flat-faced, satin black; the dash should be smooth matte finish. The seats and door panels are also the 1964 style.
I'm thinking this car has been assembled from various years and who knows what the real VIN is.
The following 4 users liked this post by 67:72:
am6174uh (03-26-2024),
Bluestripe67 (03-26-2024),
leif.anderson93 (03-26-2024),
mike coletta (03-26-2024)
Cruising
Addendum:
New pics posted while I was composing my reply above. I'd steer far and clear of this car. Even giving the benefit of the doubt on the VIN tag being human error, there are too many other weird things, most of all, the '64 interior. Those gauges and the textured dash/waterfall are not '65. The gauges should be flat-faced, satin black; the dash should be smooth matte finish. I'm thinking this car has been assembled from various years and who knows what the real VIN is.
dcamick (03-26-2024)
Tether Man
Received 2,027 Likes
2019 C1 of Year Finalist (appearance mods)
