First C2 getting the lay of the land
3rd Gear
I picked up a stock 1966 triple black L79 last fall from a long time owner. The engine is going to need a rebuild, so I was planning to drop in a Blueprint 383 crate motor. The delivery date keeps getting pushed back on this spec, so now I'm toying with the idea of the Blueprint 427 SBC...I do have a 66 BB hood. I am getting conflicting info from Summit about whether it will fit with its taller intake. I see Factoid has a 427 in a 64, but can't message anyone yet. I would love to have an accurate answer so that I can pull the trigger before summer is here in Chicago.
1966 L79
1966 L79
The following 8 users liked this post by doubleb66:
3154tm (03-16-2024),
67:72 (03-16-2024),
Boiler_81 (03-16-2024),
dcamick (03-16-2024),
Kenneth bass (03-17-2024),
and 3 others liked this post.
Received 4,505 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Welcome, nice ride, good luck with swap!
Received 19,407 Likes
'20-'21-'22-'23-'24
Moved to C1/C2 Corvettes for some assistance.
Welcome to the forum and nice car. Hopefully Factoid will be around to help you.
Received 6,982 Likes
2015 C2 of Year Finalist
Have the original motor rebuilt correctly and keep driving
TokyoMark (03-17-2024)
Received 2,132 Likes
Welcome to the CF! Good looking '66, it should bring you many miles of smiles. Dennis
Tether Man
Received 2,027 Likes
2019 C1 of Year Finalist (appearance mods)
Triple Black......Most excellent!! . Rebuilding the engine would be something I would do, regardless of the replacement.....Can I assume it is original to that beauty?
Welcome!
Dcamick
Welcome!
Dcamick
doubleb66 (03-18-2024)
Received 5,605 Likes
That engine fits under the 65/66 BB hood perfectly, but two caveats. My engine has Sniper EFI. The throttle body is supposedly the same height as a Holley carb but I never measured it. You will need a low profile air cleaner. Nothing extreme, just a drop base in order to use a 3” filter. Good luck, it is a wonderful engine!
The following 2 users liked this post by Factoid:
doubleb66 (03-16-2024),
One other point. Select your front pulleys and accessories carefully. The modern heads on the Blueprint engines are drilled and tapped for accessories unlike the oem heads, but the front crossmember will not have the crank pulley clearance for some aftermarket pulleys and set ups. I ended up cutting and welding a notch for my Eddie’s set up. You won’t have to do that if you chose carefully.
C1 of Year Finalist (appearance mods) 2019
I agree with those who say to have the original engine rebuilt, but only if it's the engine that came in the car from the factory. If your beautiful car already has a replacement engine (nom), then the skies the limit. But, remember, they're only original once.
I don't worry about originality with my triple black 62, as the stamp pad info was machined off when the engine was overhauled at some time. But, the 66 is a different story, it has original engine, trans, rear end and such..........and it will stay that way.
3rd Gear
Thanks for all the comments, I appreciate it.
Yes, original born with - numbers matching L79. The cam is starting to go and one rocker (kind of charred black)
That 4th rocker is uniquely different, not getting oil through the push rod, but we pulled it and it is clear...
on the passenger side is not getting oil, makes a ticking sound even after being tightened up.
I can either:
A. Rebuild what I have and run with it.
B. Yank this motor, store it. Replace with Blueprint 383 or 427.
Guys at both Summit and Blueprint are telling me that I need the low profile spec 383 to fit under the hood of a C2, but I have a BB hood...I didn't think low profile was needed. I can get a standard 383 shipped straight away, looks like I would now be waiting a while for the 427 as well.
I can either:
3rd Gear
Received 1,540 Likes
Welcome, that beauty has a second in the passenger's seat that detracts from the car. But, perfect year car and a real beauty.
If you get it back together, Bloomington Gold is straight down RT66 in the first week of June, I think. Maybe see you all there.
Enjoy while you can.
Received 2,703 Likes
Ohio Events Coordinator
C2 of Year Finalist (stock) 2019
St. Jude Donor '14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
L79 with side pipes and knock offs
I would further diagnoses the oiling problem and see if it can be fixed in the car. then source the correct L79 cam and lifter and check over everything else wear wise and keep that motor in the car
The following 3 users liked this post by Nowhere Man:
Numbers matching you say - I would yank that baby out and get it rebuilt. Now. And don't let them remove the stamped block numbers if they can avoid it.
When done this way - your ride will be worth more with the original rebuilt motor installed versus a different small block in the car & the original L79 (needing a rebuild) sitting on a stand.
Hi doublebdd, i have a blueprint 427 sbc i put in a couple years ago, runs fantastic and summit had it at the local trucking company in 2 days . I have the edelbrock rpm intake and a 850 quick fuel double pumper carb with the super low factory air cleaner and it fits under a stock small block hood.
The following 2 users liked this post by torinodude59:
68sixspeed (03-17-2024),
Cast Valve covers are PML made in inglewood cal. sold on ebay , not cheap i saw some for sale today they are 614 , the have the breather holes on the inside of the covers out of sight , they are thick and seal real good . Patriot 1 5/8 ceramic shorty headers and sanderson sell some 1 7/8 ceramic coated shortys that fit
