Lifters
Lifters
Took engine out and it sat for a year.engine ran great when I pulled it out.put back in and two of the lifters won’t pump up.the number eight cylinder intake and number seven exhaust.our not pumping up.now I am spinning the engine with no plugs.but I am getting sixty pounds of oil pressure.do you think the other ones will pump up when I start the engine.
Received 2,130 Likes
This is a unprofessional thought. Did you actually run the engine or just spin it over.then discover your problem? Dennis
I tried that first.I spun the oil shaft till I burned drill up. None of the lifter would pump on passenger side with drill. When I spun the engine with starter they started to pump.but I have one exhaust lifter on number eight and one on number seven not pumping.
My guess would be to manually lubricate the affected rocker arms and push rods. Reinstall the valve cover then warm up the engine to operating temperature. Perhaps shut down engine several times to re-lubricate rocker arms and push rods. Oil flowing down the push rods will help with a bit of lubricant on the lifters. Engine heat might be enough to get past the oil flow problem.
John
John
Bgblock427 (03-14-2024)
