Power Antenna again
I tried a search on google for 'Helix cables'...
I did and found this..."third from the top in the picture"... looks like it?...i think its in italian..they do different types but i don't know what size they are/make...i don't speak their language, there's got to be way to make the website speak in english..
https://industriadileivi.it/en/produ...-helix-cables/
Jack, good research. Thanks.
I see English using Google Chrome.
There's the Helix cable pdf in their Download area, but I can't download here. It says error processing AI image, incorrect file extension.
I can download to my device though.
Go to MENU
DOWNLOAD AREA
(schroll down to)
PUSH PULL INNER CABLES
HELIX DRIVE CABLES
Download data sheet
it's.....
Helix-cables.pdf
We need some measurements of the antenna cable and see if theirs match.
Here's a screenshot...
Rich
Go to MENU
DOWNLOAD AREA
(schroll down to)
HELIX DRIVE CABLES
Download data sheet
it's.....
Helix-cables.pdf
Rich
I measured a existing(broken) cable I have here. From the end where the brass ball attaches.
Here are the numbers.
Cable Core diameter - 0.080"
Helix diameter - 0.140"
Wire diameter - 0.040"
I measured apx 0.10" between coils. That's 10 threads per inch.
0.140" is 3.550mm
The Helix cables supplied by that Vendor in Italy are spec'd for several auto & marine applications.
The smallest they offer is a "flocked" Helix cable. 4.70 mm.
4.70mm is 0.185039", which appears may be too big. Not a perfect match size-wise.
More info later.
Rich
0.140" is 3.550mm
More info later.
Rich
0.140" is 3.550mm
More info later.
Rich
0.140" is 3.550mm
More info later.
Rich
Does anyone know Greg well enough to ask him where he was getting both the cable and the mast assemblies. I would think that he would help since he is no longer doing them. Just a thought.
Jay
Jay
I know Greg but a buddy of mine is really good friends with him. Greg is unable to remember where he purchased the cable due to the fact that he had a medical issue a while back that negatively impacted his memory.
Jay
Helix Cables
I sent an e-mail to this Italian company with a picture of the actual cable the the great pics and measurements from Rich asking of they manufacture a Helix cable to those specifications
I will advise
Paul
I will advise
Paul
fsc66 (03-20-2024)
fsc66 (03-20-2024)
