Will a 61-62 soft top fit a 59-60 frame ?
Hey guys,
I wonder if the soft top fabric/canvas made for a 61-62 frame will also fit a 59-60 frame ?
The reason why I ask is that 61-62 soft tops are much cheaper than the 59´s.
(61-62 = $230, 59-60 = $1000)
I know the rear bow is different, and some other brackets, but are they interchangeable with some smaller modifications or are they way off ?
Received 6,547 Likes
C2 of Year Finalist (track prepared) 2019
I don't know the answer but I find it really odd that the '61-'62 tops cost so much less. You'd think that little whoop-dee-do (technical term) in the rear bow would make those tops more expensive.
Overall, the dimensions of the two tops are virtually the same. In fact, it's possible to put a '61-'62 top on a '58-'60 with only minor changes to the rear bow swinging tie down links. So maybe you could buy a '61-'62 rear bow and install the less expensive top. Dollars to doughnuts, no one will ever notice.
Arnold-74 (03-11-2024)
Wow...love that answer ! 👍🏻
I dont like to overpay and I love a challenge.
Some years ago there was loads of used/new soft tops for a 59 on ebay. Now strangely the lower priced onec are for 61-62's only. The sellers dont know the differnce between them
.Will update this post when I know the outcome in detail 👍🏻
Arnold-74 (03-12-2024)
Did not find Al Knoch soft tops at first but they are $445 which is reasonable.
Thanx
