2 questions for a new owner - muffler and tires
I would like a couple of opinions/thoughts on the two questions below for a new 1964 corvette owner - it's a driver and not a show/trailer queen (no harm intended).
1. I need to replace my mufflers in the very near future. Would you take it to a muffler shop or my local shop that works on classics?
2. I need to replace my tires and I have the knock offs which are in really good shape. Would you take it to the local Goodyear or should I see if the repair shop can do it? And that is, if Goodyear would do it. I just don't want my knock offs all beat up.
Thank you!
Thank you!
Regarding the muffler, I would get the car on a lift and do a thorough inspection of the exhaust system. Determine what you need and consider ordering parts from Corvette Central. Your local shop should be able to install them. Regarding your tires, I use a local shop that has experience in mounting tires on high end rims. I found them to be more careful than the run of the mill tire tech. Jerry
The following 4 users liked this post by Tampa Jerry:
Use the tire shop that sells fancy rims. They have different equipment. If they have a bunch of mercs and bmw probably an good sign. Or go to the local meet up for cars and ask around. Ask the ferrari guys.
bigdog1962 (02-21-2024)
2021 C2 of the Year Finalist - Unmodified
C2 of Year Finalist (stock) 2019
2016 C2 of Year Finalist
Discount tire does an excellent job of mounting tires on the wheels, but install them yourself with a lead hammer.
The following 3 users liked this post by Redbird:
bigdog1962 (02-23-2024)
St. Jude Donor '14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
I very recently went to my local tire shop and got Hankooks. The tire shop needed to order them from their warehouse but they came the next day. I watched carefully as they removed the bolt on knock offs, mounted the tires, and remounted the wheels on the car ( a 64 hardtop). There is always "one guy" who knows these "old" cars, and knows what/how to do it. But, just in case there was any questions, I printed off instructions from the internet to give him, if he needed them. He didn't need those. I was satisfied he knew what/how to do it, and have had no problem with the tires,
RE: mufflers, not yet on my '64, but on another "old" car I've got, again, I went to my local muffler shop, ordered Flowmasters, and watched while they installed them. No problems.
Supporting Vendor
Thank you for the recognition!
__________________
Low Prices | More Choices | Trusted Experts | Send us a DM
At The Store: www. discounttire.com
Online Orders: www.tirerack.com
Tire Rack Sales: (833) 514.0330
There are a few different mufflers but these are the mufflers I used. Be sure to recognize the offset inputs are different for left/right.
https://www.a-1performance.com/XLera...oductID=XS1256
Here are the L/R Corvette Central mufflers:
https://www.corvettecentral.com/c2-6...lamp-on-322349
If you happen to know of a tire store mechanic who you know for a an ironclad fact, knows all about Corvette KO installation, then I might turn the car over to him. Otherwise, never, ever let someone unknown to you remove and reinstall the KO wheels ( unless they are the recent bolt on, fake KO wheels). I put mine up on jackstands, remove the wheels/tires and put them in a trailer to take to the tire store. Then I install them myself. Been a lot of people who have regretted letting a stranger remove and install their KO wheels.
The following 3 users liked this post by DansYellow66:
Thank you!
Thank you!
You can also buy just the mufflers, and they are clamped onto the pipes.
https://www.zip-corvette.com/64-65-3...st-system.html
Thank you!
Thank you!
a very good high line tire shop can mount and balance and align. That is what I would use; specialty shops NOT just a repair shop for these operations. Also buy the best RADIAL tires you can find
