Outer bearing o-rings
Need to change the gasket between the carrier and housing. When I pull the axles out will I need to change the o-rings on the bearing if they are not broken? or change them anyway since it is apart?
If the rear bearing is for a C-1 this thread might be of interest to you.
C1 Rear Axle Bearings and O Rings - CorvetteForum - Chevrolet Corvette Forum Discussion
