4 way flasher
I used a standard flasher unite plugged into the back of the 4 way unite. It works with LED in all outside bulbs. The turn signal flasher unite was made for LED and the original would not work.
This is one that I got. Don’t know if it works yet as I’m not that far but it is what American Autowire suggested when I bought my harness.
I would think an electronic flasher in place of the stock one would work fine provided the LED's aren't in some way incompatible because of polarity. They are about the same price and plug in the same connector. Sold at local auto parts stores. You may need one with a ground connection, but I don't do LED's so I am not up on that
