Just picked up the 64, many obstacles to overcome
Received 5,010 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Replacement O rings have a questionable quality record. Do some searching on old threads, IIRC finding new old stock originals was the way to go if you could find one. Maybe quality has improved.
Received 6,978 Likes
2015 C2 of Year Finalist
I am not a fan of just throwing parts at cars but fuel tanks are cheap compared to fuel leaks and fires. And at 60 years old the tank out lived its service life. Call quanta products in Md and order a new tank with a sending unit It's peice of mind and a huge safety aspic of your car and can save a lot of headaches down the road.
I love what was said; “the car will tell you what it wants.” So true with a car like this.
vete56 (01-31-2024)
ZIP Corvette, Corvette Central are good sources for typical reproduction parts.. DeWitts for radiator.. Quanta for gas tanks.. If your tank is perfectly good, do not replace it.. Try to get an original GM sending unit seal and locking ring.. They will work better than the repros of those.. good luck
Westlotorn (02-03-2024)
I was happy to see that you got your car to a place where you can work on it! Im excited to see what you do. I really like the advice of others and am learning from this thread! "Do what the car wants" and researching the brakes before jumping in is great advice. Im looking forward to more pictures!
James
James
Received 1,536 Likes
Do some research on the sending unit before you buy one. I remember quite a few complaints about aftermarket sending units being very inaccurate. If yours is serviceable, why replace it?
Before you put fuel in it, I would suggest replacing the rubber hoses at the tank and fuel pump. Also, check the fuel line for leaks after you fill it with fuel. Old lines can develop rust holes..
no offence but its a metal/tin tank, i dont think going through the stress of dropping and changing out the tank due to a leaking seal is warranted, its not like its a 65 mustang and the tank is in your hands in a matter of minutes.
Congrats, looks like a good start on your project. A few years back we had a '63 with manual steering and drum brakes, a fun car to drive but not necessarily to park! Old classic cars with drum brakes just have to be driven accordingly.
Take a look inside that fuel tank, if it's rusty, replace. I like Zip Corvette, think thats where I bought ours [but currently out of stock]
https://www.zip-corvette.com/63-67-g...k-no-logo.html
Tether Man
Received 2,027 Likes
2019 C1 of Year Finalist (appearance mods)
Received 6,545 Likes
C2 of Year Finalist (track prepared) 2019
And how is that? I've tracked an airbox '57 with drum brakes and it slowed down upon command very agreeably. So tell me, please, how does one have to drive a car with drum brakes?
vetintheblood (02-04-2024)
#33
Tire pressure plays a big part in steering and braking. And the pressure varies depending on the tires you use.
The steering works very well when the suspension is maintained and the alignment is correct. This also means that everything is lubed well and often.
Railroadman (02-03-2024)
#35
Received 3,651 Likes
2016 C6 of Year Finalist
Not firing? Your girl friends finger nail file and a match book cover to set the points.
You have a fun vette and you can do jolly well what you want.
Carry on...
#36
#37
#38
POSSE ZR-1 Driver
I had a 64 for 17 years with manual drum brakes. They worked just fine even with a 400 hp small block. Those drums were the same size Chevy used on the 64 Impala, which weighed significantly more. With proper maintenance, the drum brakes will be more than adequate.
#39
#40
The following 4 users liked this post by Railroadman:
