bonding adhesive
Blown62 (12-23-2023)
ptjsk (12-23-2023)
Just another choice, 3M Panel Bonding. You'll, also, need the application gun.
https://www.caranddriver.com/news/a2...hink-is-tasty/
The following 4 users liked this post by leif.anderson93:
Haven’t used it for a fiberglass repair but I’ve used it for bonding metal and other things. Plenty of work time, looks pretty much like Ecklers bonding agent used to look like and seems plenty strong.
Tether Man
Received 2,027 Likes
2019 C1 of Year Finalist (appearance mods)
https://www.jbtools.com/lord-fusor-1...ow-set-7-1-oz/
As mentioned in previous threads, Harbor Vettes Erie, Pa uses this quite extensively......... Corvettes and Boat repairs
I used adhesive from Corvette Image. You buy it by the gallon. I found set up time in cool temps to be an hour or two. A little faster if it’s hot.
I really like the slow set up time. Don’t feel rushed, and I used a lot by the time I fixed all my mistakes!
But Corvette Image no longer exists. Sorry to say. I used the epoxy by the gallon stuff from Dynamic Corvettes, it's expensive but doing all 4 corners and some odds and ends, I used a gallon plus another qt. because I was overmixing every time. Hard to mix the exact amount, but given the bit of experience I have now, I could wittle it down a bit. Over $700 for all of it.
2015 C2 of Year Finalist
8115 is a great product. I don't have extensive experience with it, but I have used it many time to fill worn-out screw holes in fiberglass and to do a really nice section repair on a Porsche floor pan.
APF 7 is the best I have ever found. Lee Bumb uses this on their assembled front clips. Great product, right color and is nice and thick, squeezes out to look just like factory bonds and you can mix it for quick or slow set time.
The following 2 users liked this post by jrm5657:
65 Pro Vette (12-22-2023),
OC-1 (12-23-2023)
Panel adhesive
Norton speedgrip comes in different open times.
they had a sale last spring when purchasing 5 tubes at $65 ea you received an aplication gun at no charge. Basically the same item as SEM or 3M.
The following 3 users liked this post by agump:
Received 1,958 Likes
Pat
csherman (12-28-2023)
