61 Bubble
61 Bubble
Friend got 61 to Hawaii, bought Florida.
what cause of bubble?
is the metal rust under fiberglass or something else?
Thanks in advance,
eric0
Thanks in advance,
eric0
I can't say for sure what's under that paint all these years after the car was built, of course, But steel? I don't think so.
Might be resin-rich spots
Beautiful car by the way. A couple bubbles doesn't change that.
2015 C2 of Year Finalist
I am guessing this is the car:
https://www.corvetteforum.com/forums...nvertible.html
The paint is over 40 years old, so not surprising there would be imperfections. I see these bubbles in the seller's photos as well. It looks like contamination below the paint that caused an adhesion problem in that spot.
Todd H. (11-18-2023)
I've had this problem before as well. While there is no real solution for the issue of the bubbles other than repainting. I stuck a pin in the bubbles and massaged gently the air inside the bubbles out. It worked. The bubbles relaxed and laid down and stayed down. You could see the pin hole only if you looked for them. This could be labeled a bubba fix but can work until you're ready to repaint the car. Good luck. Marv
