[C2] Sending unit issue
Sending unit issue
New Classics industries gauges installed during restoration. Fuel gauge was not operating and looked and sending unit on bottom of tank was bad. Replaced unit and connected wires and tank float even up to top still maxes out gauge at 1/4 fill . Myself and two good corvette mechanics are at a loss. They did not test the resistance on the float assembly before install. Anyone else have this problem?
Yea, my thought also. The sending unit not sending the right resistance to gauge. Annoying as hell, these Chinese-made parts. Why to not be afraid of them taking over the world, half their military stuff would not work. :-)
Mint 66 (10-27-2023)
Disconnect the tan wire from the sending unit with key off, and measure resistance from the connection lug of tan wire you pulled off to ground. Not the wire side, the connector you pulled the tan wire from. What ohms reading? Now move red meter lead to other wire connector (can leave connected). It should read 90 ohms to ground.
Sorry a little confused, red lead to what connector?
If you want to check the sweep of the gauge, disconnect only the tan wire from the sender and turn key on, gauge should move to full.
Let's see if I can sum up better. With all leads at sender disconnected, you should read 90 ohms from where pink wire came off to ground. The resistance reading on the connection the tan wire came off varies with float position (how much gas in tank). Full tank should read 90 ohms, empty tank should read single digit ohms.
Tell me if you are not familiar with using an ohm meter and we can try another way.
The ohm meter lead (you have a red and a black, black connected to ground). Reading from the pink wire connector on the sender to ground with the meter should read about 90 ohms.
Received 5,605 Likes
Did the fuel sender come with the gauge package? The reason I ask is the C2 Corvette uses a weird powered sender and these gauges are not compatible with the oem sender without some minor rewiring.
Yes and tan wire post varies with float
Not a problem for them. They keep the good parts and send the junk to us!
True, a non C2 gauge could cause a good sender to not match. Did you get a stock style sender replacement?
Yes a 0-90 ohm stock one. One thing with the fuel gauge, their wiring recommendation different than stock. You do not use the pink/black wire. You just hookup black where pink/black was and brown on larger post. The ground spade you put nothing on
