[C2] 1967 corvette 327/300 automatic, overheating issue due to timing and tune
1967 Pedal Car Champion
Thanks for the great explanation on how they work - I've always been curious why they get easier to turn by hand after they have been engaged.
JK27294, do you know what the fluid streaking on the fan pulley is?
<whispering> I believe it's the opposite: cold easier to spin, hot hard to spin. </whispering>
The fan clutch works off engine temp so that it engages as the engine heats up. That's why it should come to a fairly quick stop when shutting down a hot engine but may freewheel a few revolutions on a cold engine.
Before going the LS route, my 327/300 PG coupe ran hot. I did everything, rebuilt engine, Dewitts, fan clutches, timing, shroud seals, you name it, I did it. All temps were verified with IR guns, very frustrating. On hot days with AC on, 210 on the highway and 225-235 in traffic. The only thing I found that helped was a 6 blade fan, but it was noisy and didn't help much. Many on his forum have C2s that run "cool", but I sure couldn't get mine to.
67:72 (08-09-2023)
The timing setting at idle is really not important. Set it so your mechanical is correct at 3,000 RPM and if your idle timing is between 4 and 12* you can live with it. Some go with 2,800 for full mechanical advance, some go as high as 4,000 RPM but most common today is to have full mechanical advance in by 3,000.
i disconnected a plate spring, and set timing to 36 degrees; however, my new base timing at idle is ~19 much higher than the 4-12 range you mentioned (and mentioned in the service manuals).
i should also mention that I have a dual point distributor with only 1 set of points installed (dwell at 30). My understanding is that dual points can work as single points when you remove the second set.
shoukd I “live with” 19 or is there something I should be adjusting?
At what rpm do you reach 36*? With only one spring, I would worry that it is coming on too fast and you may get pinging. Also 19* static for 36* total means mechanical is only 17* which would be strange. Did someone swap out the bushing under the weights? That controls total mechanical advance.
im more confused about the 19* static. Someone swapped out a ‘62 dual point distributor onto my 65 327/300.
#33
#34
Using the two standard springs may make the advance rather lazy. Check to see what rpm it hits 36*. If it is not until 5000 or so, you are driving around with retarded spark
