Radiator shroud paint
1964. What paint for radiator shroud? Obviously black! Lol. Semi gloss? Also lower radiator shroud seal, staples bent over toward top or bottom. Thanks
cramus (07-19-2023)
cramus (07-19-2023)
Begee22,
I hope you don't mind me commenting on your beautiful engine compartment picture. The heater hose routing is not like the factory routing and the heater hose off the intake manifold should run forward of the alternator adjustment brace, check your AIM if you are so inclined.
3-speed
Second vote for the Krylon Industrial Semi-Flat.
The sheen is perfect and great for a lot of non-automotive projects as well. I buy them online, 6 at a time so they come in an unopened case without getting banged up.
Krylon Industrial Acrylic Lacquer
Semi-Flat Black
product number: K01613A07
Semi-Flat Black
