[C2] QuickJack Review
#41
With all due respect, do some research on the Quick Lift. Part and parcel of the device is a built in solid mechanical locking rod...the support of the car is not reliant on the hydraulics to hold it up in the air. The hydraulics are, actually, released back into the tank when the lift is in it's raised position and held up by the solid mechanical support.
https://www.quickjack.com/about/safety/
The following 3 users liked this post by leif.anderson93:
#42
Im seventy. Been under, over and around all kinds of lifting devices in the now 100 year old family business repairing
autos and class 8 trucks since I was old enough to
walk. Was taught early on never trust your life to any lift
with hydraulics. Remember the ancient single post lifts
that telescoped into the floor? They killed more than one mechanic. QJs will obviously lift a car but if you go under it
without solid mechanical support you are a damn fool.
#43
#44
I would never get under this thing without 4 solid jack stands under it. Even the instructions say to put stands under it with the QJ. If you have to do all that, why bother with the QJ in the first place. It's only a substitute for a jack, not a stand. Never get under this thing without more backup, even the instructions tell you that because the QJ people want to avoid law suites for accidental death.
drainbrain (10-14-2023)
#45
I also have a Quick Jack and couldn't be more happier with it.
The following 3 users liked this post by sunflower 1972:
#46
Having a small garage, I carefully measured how much my '67 moves rearward when I lift my QJ 3500. It's 11". I suspended a second tennis ball on a string from the ceiling, 11" forward of my usual "parking tennis ball," and once it taps the windshield the car's perfectly positioned to where I can close the garage door with the car lifted up.
#47
LouieM (10-14-2023)
#48
Do you own one? Have you read the multiple books on safety that come with it? Either of these things? Then why comment on a useful thread that you have no knowledge about?
#49
My car’s been up for about a month on my 5000TLX mechanically locked, hydraulics unplugged, using double stacked blocks to help clear the sidepipes. Very solid. Wonderful for virtually all jobs I’ll ever want to tackle. I’ll probably use jack stands also when I get under it just to make me feel better for oil changes but really unnecessary. Terrific tool for “many” jobs and virtually all my C2 jobs. Larry
leif.anderson93 (10-15-2023)
78Hokie66Vette (10-20-2023)
#55
I retract the TLX recommendation. After lowering the label says 5000TL. I must have called and learned the TLX wouldn’t work. Dunno.
#57
Is that what you're using? I believe with our short wheelbase Corvettes, the TLX may be a bit too long. Quote from their website:
Each portable car lift model we make serves a different purpose. A TL model is still the more appropriate choice for most vehicles. The 5000TL, for instance, has a max lift point spread of 60". The TLX models are better for longer wheelbases, with a max lift point spread of 66".
#58
Yes. Love it. Rock solid. Sitting on my little, roll around stool it's been a perfect height for brake, wheel and eventually, oil/lube. In all my recent work, no hint of the car moving side to side or feeling flimsy. Regarding the length.... I didn't know there was a difference in length. That explains why it took 2-3 first lifts to position between the tires adequately. I just thot that was standard learning curve. Doubling the blocks provided additional height to clear the side pipes in front. Before I slide the QJs out I'm going to measure tire contact to front of QJ so next time I don't have to experiment for locating. Maybe tonight or tomorrow I'll post in the air. Absolutely wouldn't do any different for a C2. Larry
leif.anderson93 (10-20-2023)
#59
Quick Jack 5000TL for comparison.
#60
leif.anderson93 (10-21-2023)
