[C1] Temp hysterisis??
Temp hysterisis??
I finally got the 62 back on the road after getting the front end aligned. As I started driving, the temp gauge rose gradually all the way to 200 and then fell back to 180 as (I assume) the thermostat opened. What happened next, I have never seen before on this or any other car. The temp would rise to 200-220 and then fall back to 180. Again and again. Almost constant up and back. Thermostat sticking? I cannot imagine what would cause this behavior unless it is a problem with the gauge itself.
Any ideas?
Any ideas?
I would monitor it with secondary instrumentation (IR thermometer, thermocouple) to compare to the dashboard gauge, and take it from there. If the gauge is telling you the truth, I'd replace the thermostat.
Live well,
SJW
Live well,
SJW
Received 6,547 Likes
C2 of Year Finalist (track prepared) 2019
It's the thermostat causing that.
I've seen the same behavior two or three times.
Once was with a high zoot hot rod whiz bang thermostat I put in my race car. I cured it by replacing it with a garden variety NAPA thermostat.
The following 2 users liked this post by jim lockwood:
carl3989 (09-25-2023),
Dreaming60’s (08-04-2023)
RON
c66vet (09-30-2023)
No, they restrict the amount of flow to control how long the water stays in the block to absorb heat from the engine block. Larger hole, faster flow less heat absorbed from the block. Smaller hole, coolant held back to absorb more heat. The only downside of course, is that the cold start engine takes longer to warm up. Lots of race cars use them.
If it's a Mr. Gasket Chinese clone of the Robertshaw hi flow stat, that's the problem. I have never had one that worked right or was anywhere near the right calibration. I have 2 of them on my desk right now---A 160 that doesn't start opening until about 190 degrees and a 180 that opens at 160 degrees---They're JUNK. Get a real Robertshaw or a Stant thermostat.
RON
RON
They work for me, so for me, that makes them worth the money
I've had good luck 'in the past' with brands like Gates and Stant and Robert Shaw but just checked the Robert Shaw website and they don't show our old style thermostats.
I also checked NAPA and they do sell one that 'looks' like a Robert Shaw but in the fine print, it says it's manufactured by Mr Gasket.
I also took a pic of the Stant 180 thermo I bought a couple years ago and no big surprise, it's also made overseas...this time in Israel.
Mike T - Prescott AZ
RockAuto ..
https://www.rockauto.com/en/catalog/...hermostat,2200
My engine also experiences this phenomenon when warming up. Temp initially goes to 200, then backs down to 180.
John
John
I put a Robert Shaw thermostat in my 66 recently and it solved the problem of slow warmups and running too cold. For the first time in many years my engine and gage act normal. I would say they are worth the money.
Since it has been awhile, let me briefly recap: I have a 62 with what is essentially a 1970 LT-1 engine. It has always overheated. This year I decided to bite the bullet and installed a new DeWitt HP radiator, new hoses, new high flow water pump and new 'hi flow' thermostat (Mr. Gasket). I am not sure what makes it 'high flow', it looks like every other thermostat I've seen for SBC. That was when the hysteresis began. On advice from this thread, I swapped in a NAPA std thermostat. No hysteresis, but it was still overheating. I thought that maybe it really did need a high flow thermostat (The water pump said it needs it). I tried an Edlebrook high flow. Looked like all the others. Had the same hysteresis - 180*<>220*, Finally, I bit the bullet and bought a RobertShaw from Summit since there have been so many positive post about it. This thermostat does look different so I had great hopes. Nope, same hysteresis.
Is there ANYTHING other than the thermostat than can cause this? I am about ready to try no thermostat at all or maybe one of those restrictor rings. What are they called? Where do I get them?
Never mind. I found them on Amazon. Any recommendations for a size to start with for a street driven LT-1 engine?
Easy theory to test. Take the stadt out and drive the car. Go back and put the restrictor in (smallest hole) and drive the car and compare the results.
I would start with the middle one and then go up or down as necessary.
Keep in mind it is going to take the car a lot longer to warm up than with a conventional stadt.
Good Luck.
