Denso/NGK Spark Plug Conformation
I'm going to put a fresh set of Spark Plugs in the Vette. 67 327/300HP. Stock. Weekend/Daily cruiser. Occasional rips at full throttle here and there.
Going with the AC45 heat range. Thanks to Duke and others for the info as I was searching the Forum.
Denso: The exact Part number I got for the Denso is 6008 W-14U. That Correct?
https://www.densoproducts.com/denso-...ove-spark-plug
Also they come Gaped at .028 is that good or should I open it up a bit? .030-.035
NGK: I could not find the exact part number for the NGK B4. Need help with that.
Also the car gets parked on a Stacker. Easier to get to the plugs from the bottom or top?
boat196 (06-08-2023)
I used the Denso’s that you listed. I gapped them at .035. They work well. I changed mine from above except for numbers 6 and 8. I tried to get them from above, but it was easier for me to change those two from underneath.
mblake101 (06-03-2023)
I went with the NGK plugs and i'm happy with them. I'm sure the Denso plugs are great but i just don't have any experience with them. If you're also thinking about replacing plug wires i used Napa- Belden 700103 for my '66 L79. They are lifetime warranty and 7mm so they will fit under ignition shielding. These are precut and correct length to fit under your shielding with routing through all the shielding. Napa website list the wire lengths as well. Just installed these and love them. Cost roughly $43. Good luck.
Dwain
Dwain
Dwain
Dwain
1967 Pedal Car Champion
The NGK XR4 (#5858) plug is equivalent to the R45S, which is recommended today for modern fuels. The B4 you are asking about is #3210.
Attached is the NGK cross reference guide.
Thank you very much. If I remember right the R45S is the "extended tip"? So the XR4 is also an extended also?
- NGK-B4 and Denso-14U are Non-Resistor plugs like the orginal OEM plugs
- Resistor plugs are the best choice if you have static/noise coming through your original radio other wise non resistors plugs work just fine with ignition shielding.
- Best prices I've found for the NGK plugs were on RockAuto or Amazon. RockAuto can be costly with shipping if you are just ordering plugs alone.
Turbo Kyle (06-03-2023)
I went with the NGK - XR4 (Part#5858) equal to ACDelco R45S (S means extended) - Both resistor plugs.
NGK and Denso are both very good spark plugs. I, personally, run Denso 14U. Almost 4 years and 24000 miles on the current set and they're still performing fine.
