Recommended Alternator to run Vintage Air
Hello,
I'm restoring my 64 corvette and I'm planning on adding Vintage Air. I'm going to upgrade to the Dewitt radiator with Spal Fan, but I'm not sure what alternator I should go with. I also already bought the new wiring harness to replace in the Corvette as well and I believe this connects to the alternator. I'm looking to find what you guys have used and/or recommend. Also, what gauge wire I should run.
Thanks,
Lynda Hernandez
Thanks,
Lynda Hernandez
Hello,
Thanks,
Lynda Hernandez
Thanks,
Lynda Hernandez
I'm sure some of or experts will jump in here and make some good recommendations. I have found that The Power Master is a High Quality Alternator
This one shown has a Serpentine pully but the same unit is available with a V pully
. https://www.summitracing.com/parts/p...NBSmjQY0TFkZT0
jerry gollnick (05-20-2023)
I'm running a Power Master 140 Amp alternator plus a DeWitt's Dual Spal Fan system and a Non Vintage Air system. I believe each spal Fan will draw somewhere between 20 to 27 amps when they kick in. Plus the A/C Compressor is some where in the high 20 amp range. Someone here can correct me if I'm off by a few Amps. Either way I would upgrade your alternator as it is running your electrical system and at the same time trickle charging your battery. I can watch my Volt Meter drop when the fans or Compressor kick in and them come back up. I'm running a Digital Dash which uses a Volt meter instead of the stock Corvette Amp Meter.
I'm running Vintage Air and a Dewitt Radiator with stock fan and shroud and the stock alternator. If you go with a Dewitt Radiator and have a stock or mild engine, you won't need an electric fan.
59BlueSilver (05-20-2023)
I already ordered the Dewitt with the Spal fan, that's why I'm thinking I should be running a higher amp alternator. I'm rebuilding the 327 engine and I've upgraded the the cam and lifters, not sure if that matters. I know it is the higher hp engine.
Copied from another thread I posted on asking a similar question:
As far as the alternator goes, I had to go through a couple with increasing output to find one that would support all the electric systems I am running, such as an electric fuel pump, Sniper EFI,
Vintage Air, electric radiator cooling fan and a number of electronic instruments, not to mention the stock stuff like lights.
I ultimately ended up with a Powermaster 47293, which is rated at 150 amps
It took me a number of tries to get the wiring, fuses and relays right for running those fans
I think I finally have got it dialed in
Glenn
Glenn
CorvetteMikeB (05-19-2023)
Glenn
Glenn
I would wire that system & copy the way Glenn did his install, relay’s & circuit breakers are the way to go check out his 63 build post’s.. Sorry Glenn don’t mean to put you on the spot, but Lynda finding the right alternator is only the start I wish I had more info for you but I’m still a year or two away.
Good Luck
Happy reading
Chalie
This may be a little help check out this harness conversation from your stock 64 alt. Plug to the needed CS130 alternator plug & 64 v/regulator eliminator..
https://www.zip-corvette.com/63-68-a...lternator.html
Regards Chalie
Regards Chalie
JPB04619 (05-20-2023)
Received 1,591 Likes
St. Jude Donor '20-'21-'22-'23-'24
I added Vintage Air and a DeWitts combo radiator and Spal fan to my’67 10 years ago. I rebuilt my alternator to 100 amps at the same time and haven’t had any issues.
Steve
Steve
There yah go.. The Ratdog says it all...
Steve
Glenn
Glenn
Check this site out for all your electrical needs, purchased some items in past (way before the Covid), no complaints:-)..
https://www.delcity.net/?mkwid=s&cri...SAAEgJyIvD_BwE
Chalie
Chalie
Chalie
Chalie
Thanks for the kind words.
I am running a single Spal fan on a Dewits radiator, and I consistently underestimated how many amps that bad boy would draw
Especially when first kicking in.
Plus the vintage air fan and compressor sucked more as well
We started out with a 30 amp circuit breaker with an automatic reset coming off the battery, which led to mysterious power outages which couldn't be
initially traced because the breaker would reset. It was a crazy maker. LOL
I finally ended up with 80 amp circuit break that didn't reset and it has yet to blow
For the fans we have now two 40 amp fuses running in parallel to just the fans alone.
In fuses for a house air conditioner they use slow response / time delay fuses to get over that initial power draw when it starts up
Automotive fuse tend to be just the opposite. Quick response.
I am looking forward to testing the entire set up in 100 F temperatures. 80F has been the hottest so far.
lyndahern (05-19-2023)
Interesting tech this site will answer many questions... I chose this section..
http://www.madelectrical.com/electri...esensing.shtml
Ten go back to the home page for more info
lyndahern (05-20-2023)
I use #8 gauge wire from the Power Master 140 amp Alternator thru to a 135 Amp Circuit braker to a fuse array which runs to my horn relay then out to the electrical system. If the alternator diodes go to ground then the CB fires off. Extra protection. I use a 30 amp fuse on each spal fan also as well as the A/C Comp. The Power Master is using an internal Voltage regulator and the voltage sense line goes to the Horn relay to control the output of the PM.
one similar to this one except mine is rated at 135 amps. https://shop.advanceautoparts.com/p/...E&gclsrc=aw.ds
Glenn
Glenn
Lynda
Also added additional ground wires to the frame to the engine block. A good solid ground is the best way to go,
