Recommended Alternator to run Vintage Air
Received 5,615 Likes
You also need to run at least an 8ga wire from the alternator output to the battery (connection on the starter is easiest.
My 8 gauge wire runs to the horn relay. The charge wire is the stock I believe 14 Gauge to limit battery overcharging which runs to the battery from the horn relay. Before it gets to the Horn Relay it goes thru a 135 amp circuit breaker on the inner fender next to the Alternator. A internal diode failure in the Alternator is something you don't want ...hence the CB.
elwood13 (06-29-2023)
I have the Concept 1 serpentine system with their bigger Power Master alternator. I am a running a lot more electrical goodies though. Great company to deal with by the way.
