[C2] Armature Difference Headlight Motor
Tether Man
Received 2,027 Likes
2019 C1 of Year Finalist (appearance mods)
Question: Not ever owning a C2 Power Window Corvette, Are the Armatures different in the window motor vs. the headlight motor? Or are they the same?
I just purchased a replacement Armature for my spare headlight motor and the Bushing END shaft of the Armature is measuring at .3150 and is extremely tight starting into the housing bushing. the removed Armature bushing shaft is measuring .3125. The armature stack is also larger in diameter....So, did I buy a piece of junk? Oh, the bushing was not changed.
Thanks!
Dcamick
Thanks!
Dcamick
I've repaired both. They are similar but not the same. If you would like me to check my picture file I believe I have pictures of both as well as the insides. I'm not on my home computer right now so no pics.
65-StingRay, Wayne
65-StingRay, Wayne
Tether Man
Thanks for responding. The Item I bought on Ebay was very minutely different. But Critical, as mentioned.. I could make an assumption that the window motor armature is slightly larger (Shaft, Stack). Anyway, I have returned the item and will check elsewhere for a replacement.
If you get a chance, I would love to see a picture of both.....
Thank you,
Dcamick
Here's a pic of the power window armature:
headlight armature
I hope these are the pics you need. If not I have many others.
65-StingRay, Wayne
headlight armature
65-StingRay, Wayne
dcamick (04-01-2023)
Tether Man
Thanks for the pics!!
Tether Man
Tether Man
With that being said, my only option would be an armature rebuild.....Or, pulling out the bushing, retainer then drilling out the bushing. As mentioned the stack is also a larger diameter...... I see no reason why any Vendor or Manufacturer would change these critical dimensions..CHINA?
