Headers for raised port heads
Planning to install an sbc 427 in my 67 coupe. The motor will have angle plug AFR heads with slightly raised exhaust ports ( .250 inches raised ) Would like to run 1 3/4 primary tubes headers. I've got oem power steering & AC.
Anyone gone down this road without making custom headers or reworking header flanges to align with cyl head exhaust ports ?
So many header brands are under the umbrella of large companies like Holley or pertronics so the tech guys don't seem to know enough detail about their products re: raised port fitment.
I was thinking about headers designed to fit SBC " D " port heads as their ports are a bit higher above the bolt center line and could work. Trying to avoid ordering and sending back multiple headers.
Try McJack’s Headers . They’re not cheap, but anything that works is worth a bit more. They most likely have what your looking for.
If you decide to try a set of SBC headers, I can recommend the set I bought from the Facebook Marketplace for less than $100. You can see them in post #11 of this thread
Location: "You may all go to Hell- and I will go to Texas- Davy Crockett
St. Jude Donor '12
I am using AFR 227 heads, and using 1 3/4" 2108 Hooker headers on my 62. I think they raise the bolt holes in the heads a corresponding amount. They fit perfectly
Thanks ... My car is a C2 gen so different application than yours. You may have have more clearance in some areas than I do. Sounds like you were fortunate to have them fit with aftermarket heads
C2 of Year Finalist (performance mods) 2019
I think I have Heddman. I need to pop the hood to figure out what brand I have for sure, but I have Edelbrock RPM heads with raised ports and factory side pipes. I went through so many different headers until we found the set that I have, but I don't seem to have the make/model written down.
Received 5,598 Likes
Mark, I’m using Doug’s headers on my BPE 427 sbc. I just saw your PM and will call tomorrow. Here’s the part number: https://www.summitracing.com/parts/d...b#applications
St. Jude Donor '12
I also have a set of #2234 Hooker 1 3/4” long tube headers that the afr heads clear easily. They are for a 63-67. There is tons of room on a midyear compared to a 58-62. I have trial fit them and they fit nicely.
Which afr heads do you have ? If they are 195's , the ports are only raised .100 of an inch which is negligible but if they are 210's + , then they are raised about .250 inches
Mark
