$900 Paint, Chapter 2, Strip/Prep
So far, cost is less than a hundred bucks and there is very little cost in this chapter: one gallon of stripper, blades, lots of paper towels, and a few disposable paint brushes.
The car is now disassembled, including buckets, hood, rear valance, and windshield molding, glass is still in place. I used a razor blade on about half and Cleanstrip from Lowes on the other half. If doing this again I wouldn't use the blade, it's almost impossible not to nick the surface occasionally. On the concave parts (coupe especially) the razor doesn't work so well.
Brushed the stripper on about a 2'X2' area and wiped it off with a rag soaking wet with water in less than five minutes. Usually about three times and the OE lacquer was off and I had a good clean surface. Water neutralizes the stripper instantly, use plenty of it.
You might skip this next step on a convertible, but on a coupe remove the windshield and side glass. Carefully strip the areas under the windshield and under glass run channels in the door. I did have to buy new glass runs because I couldn't get the old ones out unharmed. Now a problem; it was obvious that removing the molding around the back glass I was going to damage it, so I left in place and used a toothbrush to thoroughly strip and clean around it. I'll address this molding issue again when taping in the next chapter. This car has very nice weather stripping because it was in storage from 1971 to 2019, I'm not changing the color, and it's a driver, so I won't paint the door jams. I'll mention more on the door jams in the next chapter. Notice a factory defect in the roof just to the left of the peak by the glass, it was fixed with some very hard substance. Now another through washing, move it to the painting area where it will be for some time, put it on jack stands and remove the wheels. More in a few days.
The following 13 users liked this post by polo91:
62vetteuk (12-28-2022),
67:72 (12-28-2022),
Brian VH McHale (12-28-2022),
ChrisBlair (12-28-2022),
DansYellow66 (12-28-2022),
and 8 others liked this post.
I’ll be curious if you have any issues or special procedures for tying/blending the new urethane into the lacquer jambs. I like this series of threads.
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
St. Jude Donor '11-'24
Slow, but steady
I’m stripping the paint on my ‘70 Coupe. I’m using airplane fiberglass stripper and lacquer thinner to rinse it off. Slow, but steady.
Bob K.
Bob K.
67:72 (12-30-2022)
vettefred (12-31-2022)
My 57 had been repaired and painted so many times that I used 36 grit on a long board to strip it and level it at the same time/
The star bursts on the front fenders were ground out and filed with glass mat, followed by a cost of random glass mat over the whole top of the fender.
No ill effects from using stripper the paint on the car was done in 2011.
John
Bob K (01-30-2023)
Bob K (01-30-2023)
It looks like you've had good results with the KleanStrip. I've used it in the past (20 years ago) and had good results also but when I've used it recently it wouldn't soften the paint at all. I think at least in California it has a different formula now? Does anyone know if California KleanStrip is different then say Texas KleanStrip?? Thanks
Paint stripper
My car had 3 layers of paint. The original lacquer was easy, but the outer layers were tough. I found an old can of stripper at a yard sale that had methylene chloride, it worked pretty well. Newer stuff wouldn’t touch it
But for most of it just scraping with a razor blade worked best. Then stripper in corners and concave areas. Toughest was areas I couldn’t scrape like irregular door jam surfaces
