[C2] What's the cooling capacity of an original PG trans cooler?
I can't find any data what the BTU value of a PG trasnmission cooler in a C2 is. I'm curious how it compares to a modern small Derale plate and fin cooler.
Received 2,143 Likes
2015 C2 of the Year Finalist
Dan
Well Dan, that's exactly my issue having upgraded to a 700R4 which would probably benefit form a better cooler.
I'm installing a 2004R into a 65 and eliminating the external cooler for one in the new radiator. My thought is that the lock up torque converter will produce less heat than the PG. I've installed several of these transmissions in C3's using the integrated cooler in the radiator without issue.
Dan
Received 2,121 Likes
There are pro's and con's for both internal and external. I like the internal cooler because it's very efficient and also helps the trans get to operating temp in cool weather. Another thing not to my liking is the external cooler taking up real estate in front of the condenser as well as the extended rubber hoses. If this were a tow vehicle, then more cooling might be needed. My C3 has a trans temp gauge as well as the internal cooler, it runs within a few degrees of engine temp which is ideal.
