[C1] Shocks and other simple suspension improvements - Suggestions
Are there any common suspension improvement suggestions for a 1961 C1 that don't involve big modifications or dollars? Progressive shocks, different roll bar, etc?
Be sure all your rubber bushings are intact and serviceable, gas shocks, radial tires and a quality alignment. That's really all you should need for a driver quality car.
High pressure gas shocks were not around when these cars were designed, and will increase the riding height of the car by some small amount (depending on the gas pressure).
The original Delco shocks were low pressure, unlike today's shocks.
Good luck!
Plasticman
Good luck!
Plasticman
There are no rubber bushings on C1 front suspensions.
There are rubber shock bushings, anti sway bar bushings and the rear spring eyes and the radius rods have bushings, those should be checked to make sure they are in one piece.
A LOT of these old 1949-1954 Chev front ends are worn, the metal shafts or metal bushings or both, along with kingpins.
Maybe a knowledgeable (not run by 25 YO kids) can inspect the front for you.
I can tell you when i rebuilt my totally worn out front suspension, in 1995, it made a world of difference, the car went from the equivalent of trying to drive a pizza plate on marbles, to something that steered and handled and drove straight.
Doug
Doug
I'm capable in looking at the standard suspension and sway bar parts and inspecting and fixing. I'm really looking to know if there are any upgrades that are well known among the C1 owners. I do need to replace a number of rubber bushings. I was also wondering if there are some decent progressive shocks that are known to work well for these cars. The standard shocks on there were clearly replaced in the last couple of years, as they pretty new, but they are definitely standard shocks.
Received 3,050 Likes
C1 of Year Finalist (performance mods) 2019
I had them on my 57 but I thought they rode stiff. As stated you need to keep aC1 suspension well greased and often. The king pins are metal to metal and not fun to change.
I have installed a lot of bilstein shocks on first generation buick rivieras and they make an amazing difference. We are all now used to modern car rides and the old cars just do not hack it. Bilstein shocks really help. I did not install them on my 66 Corvette as it is a survivor car but I know that they would make a very good difference.
Doug
There are no "simple" improvements, fancy shocks won't do anything for you.
These suspensions are actually pretty nice, IF, they aren't worn out, and unless your was rebuilt, which i doubt based on those fuel lines, THAT is where you will get the most improvement, though i doubt you have inspected anything properly to determine that.
Doug
Doug
JF in MI (07-29-2022)
- Water pump replacement and front motor mount bracket replacement, along with aftermarket fan & fan spacer
- Clean up and repaint of engine, brackets, generator and many areas under the hood.
- Replace most of the rubber under the hood - lots of deterioration
- Repair wiring harness and properly route under the hood - it's a real mess to be kind with some awful splices and weird wire routings
- Replacement of distributor with billet electronic type, wires, separators, coil, etc.
- Replace fuel line and hoses front to back - another train wreck here with multiple poorly done patches
- Repair/upgrade brake system - master cylinder is toast and fluid jelled up in it.
No, not yet. I'm currently in the middle of fixing so many things on this car just to make it drive-able. I started with a simple carburetor rebuild just to get it running, which led to one thing after the other. I'm peeling the proverbial onion in what little time I have. I honestly shouldn't have even asked about the suspension yet, but when I was under it a few nights ago working on the engine clean up, I was looking around for the grease zerks and was prying on suspension parts to check tightness when suspension upgrades came to mind. So far, all the suspension feels tight and I don't get squeaks or grinding when I bounce the car. Shocks are in good shape. Steering feels tight and I don't see any play. But honestly, the suspension comes after everything else listed below that is now in progress, but before it starts being driven.
The biggest improvement in quality of ride, road feel and cornering on my car was the addition of KYB gas shocks.
ScottAC8DE (07-29-2022)
I should mention that the reason the distributor is being replaced is because the bushing it has a bit more play that it should and the desire to get away from points. And since it is not a "corvette correct" distributor anyway, the change makes sense.
There are no "simple" improvements, fancy shocks won't do anything for you. These suspensions are actually pretty nice, IF, they aren't worn out, and unless your was rebuilt, which i doubt based on those fuel lines, THAT is where you will get the most improvement, though i doubt you have inspected anything properly to determine that. Doug
