Hemi/Vette update
Hemi/Vette update
Well last week I added that clear protective sheeting to the front. A black car doesn't like bugs or rocks so this should help. Now tomorrow I'm having the rear updated to a 3.7:1 from the 3.2:1.
scotty t (05-22-2022)
Received 3,043 Likes
St. Jude Donor '05
& a bikini model showing it off. That doesnt go by the name of Frank Footer
Thanks, know we can count on you!!
In the shop this morning. Should be done this afternoon. Ok here's the engine. Then a 5spd TEMEC and a Chrysler 8.74" rear (now getting the 3.7:1 ring and pinion) with 4 link suspension and coil over shocks.
The following 8 users liked this post by 911Kolsen:
beatlescott (05-23-2022),
carl3989 (05-23-2022),
Dave64 (05-24-2022),
Howielones (05-24-2022),
ptjsk (05-23-2022),
and 3 others liked this post.
scotty t (05-23-2022)
Got her back from the shop yesterday. Now I have to figure out how to correct the speedometer. Looks like it's about 8 mph fast?????
scotty t (05-25-2022)
Replacement gear for the speedo drive on the way from TREMEC. Ahhh do I love to drive this old girl with the top down and that old Hemi rumbling along.
scotty t (05-27-2022)
carl3989 (06-03-2022)
The following 2 users liked this post by scotty t:
65air_coupe (05-28-2022),
carl3989 (05-27-2022)
Location: "You may all go to Hell- and I will go to Texas- Davy Crockett
St. Jude Donor '12
I am sure you have posted the specs on your Hemi before, but for those of us who missed it, could you repeat please? thank you.
Edit- in looking at the pictures of your car I can see a 392 badge like comes on the new Charger/Challengers. Cool... What mods have been done to it?
I put the 392 on the hood as a tribute to this installation. When I go to a car show I like to leave the hood down until I get questions like: "isn't that supposed to be 396? Is it a 383?". Then I pop the hood and the jaws drop, ha ha.
I haven't done much to the engine just rebuilt both Carter AFB's, replaced the twin point distributor with Pertronics. replaced the old Chrysler transmission with a TREMEC 5spd, replaced the leaf spring in the rear with 4 link suspension and coil over dual adjustable shocks. Since 65 was the first year of 4 wheel disc brakes I took the drums off the Chrysler solid axle and added aftermarket discs. Lastly I added a small rear spoiler in memory of my old 65 Vette I had 50 years ago.
vettsplit 63 (05-27-2022)
Well the first replacement gear I got from TREMEC for the speedo drive was wrong. Only changed the speed by about 5 mph. Still 5mph slow so another gear is on the way, that should correct the speedometer back to the actual speed, according to my GPS. Can't remember what I used to do back in the days before GPS. I do remember once I was at the airport (where I worked) and a friendly cop parked on the taxiway and I ran straight at him and his radar. Really accomplished two things. Got my actual speed and found out how close I was before that fiberglass car tripped the radar.
If I still remember correctly I used to run 60 mph as close as I could hold it down the interstate in KS and clock off my time for 3 miles on the mile markers. Take the total seconds I clocked off by watch, divide by 3 in my head, divide that by 60 in my head and multiply by 60 mph in my head = corrected mph
2 minutes 49 sec to go 3 miles / 3 = 57 sec/mile
60/57 = 1.055 factor
1.055 x 60 indicated mph = 63.3 actual mph
i was a lot better figuring in my head back in my college days in the slide rule era than I am now.
Art Work!
That's so pretty it would look great sitting in the living room. Hey why not? I've seen rich guys parking classic motorcycyles ( Knuckle Heads or Brough Superiors for example) in their living rooms, because they consider them art work. I don't consider that motor anything less. You are truly blessed Sir.
