[C1] Looking for advice on my first C1
I just picked up my first C1 (1962). I’ve had a couple of C2s, currently a 65 roadster.
The 62 is NOM with a 69 350, 4 speed.
I’d like to make the car more driveable while staying within a budget (i.e. not replacing the chassis). I just want to have an acceptable driver.
The car appears to have the original steering and suspension, although the PO was going for a gasser look and the car sits a bit high. I’m not sure yet how it was raised.
The car does not steer / handle very well. I realize the C1 steering and front suspension technology is old school and wonder what options would give me the best bang for my buck?
carl3989 (05-14-2022)
Pro Mechanic
Received 1,313 Likes
2023 C1 of the Year Finalist - Modified
A new C1 rides, handles, and stops like a brick compared to anything contemporary. It's what makes them what they are. That said I have yet to see a C1 that didn't need some front end parts, not that the owner didn't want it fixed but couldn't find anyone who knew how (or would admit they knew) how to fix them. The #1 best thing I ever did to mine to make it lightyears more enjoyable to drive was to add electric power steering.
64luke (05-14-2022)
min the meantime, here’s a short video the PO took. Please excuse the filthy undercarriage. This will be addressed!
Did you go with a Steeroids setup?
Pro Mechanic
I went with a system like the EPAS power steering kit however I made up my own kit out of scrounged parts. Here is the link to that post.
https://www.corvetteforum.com/forums...onversion.html
C1
Those cars were driving everywhere as commuter cars when new. Put a good (not cheap) set of radials on it and see how it drives. Fix any existing suspension issues. I
Received 3,050 Likes
C1 of Year Finalist (performance mods) 2019
The best things you can do to improve handlings are complete front end rebuild with Moog rubber components, keeping the entire front end greased regularly, don’t overlook the 3rd arm as there can be a lot of play there, radial tires, at least two shims per side between the frame so you can get more alignment adjustment, (you will definitely need this for the power steering) alignment, electric power steering.
This is all you can do without replacing the entire front suspension which is VERY expensive. I would also suggest replacing the steering wheel with a 15” and adding the factory type quick steering adapter AFTER you add the power steering as it gives you more entry/exist room and driving comfort especially during spirited driving.
The car has BF Goodrich Silvertown Radials -
P225 70R15 on front and P255 70R15 on rear.
Moog rubber components????
Other than some grease seals, there is no rubber in the front end.
You will want to have competent alignment shop check play in the kingpins, and on the upper and lower inner control arm shafts and bushings. Thats where Moog steel bushings and cross shafts come in, if you c an find original Moog parts, if they are sloppy and need replacing. Upper and lower out shafts/bushings are also important, but don't create as much OMG steering issues if they are worn.
My '61 used to swap lanes unexpectedly until i rebuilt the front end three decades ago. Now, it steers and handles pretty nicely.
Doug
Doug
The following 3 users liked this post by AZDoug:
Received 6,547 Likes
C2 of Year Finalist (track prepared) 2019
The key thing to know is that if everything in the front suspension is in good condition, a C1 tracks well, has relatively easy steering, and has no particular vices.
I've driven two C1 Vettes from the right coast to the left coast without issue. I'd do it again in a heartbeat as long as the steering and suspension was in good shape.
64luke (05-14-2022)
You will want to have competent alignment shop check play in the kingpins, and on the upper and lower control shafts and bushings. Thats where Moog steel bushings and cross shafts come in, if you c an find original Moog parts, if they are sloppy and need replacing. Upper and lower out shafts/bushings are also important, but don't create as much OMG steering issues if they are worn.
Doug
Doug
Rosco 1962 (05-14-2022)
It would help if you could quantify what this means. Does it wander when going down the road? Is there a lot of slop in the steering? Is the steering effort greater than what you expected? Are you trying to corner at the limits of tire adhesion??????
As I’m heading straight down the road the steering almost seems to “knuckle” from side to side.
Pro Mechanic
>I've driven two C1 Vettes from the right coast to the left coast without issue. <
You're a better man than me. My *** can only handle C1 seats for about 2 hrs max at one time.
We don’t do any aggressive driving. This is a car we would like to feel confident in driving around town or on highway.
Pro Mechanic
If everything is tight and the steering box bearings are OK there should be no issue with going down the road straight particularly with radials. Radials will generally make a big improvement over the bias ply tires they originally came with because the sidewalls tend to absorb bumps a bit better and they sit "flatter" putting more rubber on the road and don't "dart" when crossing a seam in the pavement. They do, however (IMO) increase the steering effort a bit. I only have one shim in the suspension assembly (was going to put 2 in but decided it was to much of a PIA with the car fully assembled) and it tracks fine.
