[C2] Distributor length
Received 3,050 Likes
C1 of Year Finalist (performance mods) 2019
Distributor length
Basically the REAL question here is about the distributor length and what it will fit in but I am going to give you the background on all of this.
Ok, so a while back I bought a K66 UHV ignition system basically for the coil and intending to convert a tach drive points distributor with the parts out of non tach drive distributor that came with the system I bought. Turns out converting the distributor with the parts from the other distributor is not possible. So I am going to sell the complete system that I bought but am now trying to figure out what I actually have. I have been all over Chevelle, GTO, Z28 and Chevy Super Car sites trying to figure it out in addition to a site with a lot of info about UHV systems.
The distributor I have with this system rotates the same direct as Chevy but is 1/4” shorter than a Chevy distributor measuring from where it sits on the engine block to the bottom of the shaft. which is 7 3/4” verses the known Chevy distributor that measures 8”. Will this shorter distributor seat probably and work in a Chevy BB engine?
Regarding the system I am trying to identify it MAY be a put together system based on what it includes:
1. The distributor has absolutely no part numbers on it.
2. It has a vacuum advance unit on it that is a somewhat rare Z28 unit which is marked MS 400 15 not sure if this UHV system was available as a factory installed option or just an over the counter parts on a Z28?
3. The coil is a #248 CD which is supposed to be for both Pontiac and Olds but will also work with any vehicle with UHV system.
4. The UHV amp box has a very lightly stamped part number that LOOKS to me like 1116030 but I have not been able to find the application.
Here is a picture of the system.
Received 6,979 Likes
2015 C2 of Year Finalist
Didn’t like our answers on Team Chevelle. I stand by what I wrote over there
Baron (04-14-2024)
My question here is the same as I have asked on other forums regarding the distributor length and if it will work in a BB Chevy engine that so far NO ONE has answered.
Location: "You may all go to Hell- and I will go to Texas- Davy Crockett
St. Jude Donor '12
St. Jude Donor '12
I don’t care what your opinion was there since it has yet to be determined what the original application was that you seem to GUESS at. and it is yet to be determined what I really have or what the original application was at this point. Your opinion on it’s value was ridiculous. Have you ever tried to buy even a good K66 coil for an example lately?
Chevrolet distributors Bb and SBC are 7 3/4" from the bottom of the mounting base to the bottom of the gear. The bb truck block uses a different length.
I believe some of the old truck engines were what they call high deck blocks.I would think they would need a LONGER distributor if I am understanding what that is correctly?
there is no guessing. These items are not assembly line parts ever used on production cars. Over the counter speed parts don’t bring as much money as assembly line parts. I know what assembly line TI coils sell for.
So, based on what I stated I have in the OP with the Z28 specific vacuum advance unit I should think that this system was likely used on one of those cars. I have not yet had an answer as to weather or not they were factory installed on those cars or if maybe this one was sold to someone that bought one over the counter for one of those cars.
That is a possibility as they apparently used these UHV systems on HD trucks, military vehicles, on Oldsmobiles, Pontiacs, Chevelles, Camaros and we’re sold over the counter as well as factory installed on SOME of these cars. I just don’t know if 1/4” difference would keep this distributor from fully engaging ad working properly? I would like to sell the complete system but need to know what it will fit and work properly in. I don’t want someone to just take a chance on it like I did that did not turn out well for me.
Why don’t you just try and find ANY TI coil and see what you can buy it for or the amp box or a distributor if you think they are all over the place for sale? I have been around a old classic cars probably longer than you are old. I was going to Bloomington in the 70s when it was originally in BLOOMINGTON and lots of other swap meets over the years and I have never seen one of these systems for sale ANYWHERE until I bought this one so obviously they were not growing on trees.
tuxnharley (03-30-2022)
It's possible that to he gear itself is longer for some reason which wouldn't affect the fit or function. Measure from the bottom of the mounting base to the bottom of the actual geared part of the distributor gear, mine measures just over 6 3/4". If they made the gear itself a little longer on the round part that would just help stabilize the oil pump shaft a little better.
it looks like you have a mix of parts to me.
Distributor looks like standard chevy. I think 7 3/4" is the correct length.
the UHV on the box and the red coil are what was used on Oldsmobile. think that was an option around the 1967 time frame on the W30 cars. i think these systems were also used on on the baldwin motion cars. so im guessing someone got their hands on an oldsmobile system, but needed it for a chevy so found a dizzy
also im just curious- why cant the tach drive dizzy be converted? im new to TI myself piecing a system together for my car, but from everything i read there is no difference in the housing between TI and points. just wondering what is up with that dizzy
edit to add- i happen to have an original vette tach drive TI sitting here. i measured it is exactly 7 3/4"
yes I get that, i was referring to the length being the standard chevy length.
Good luck in your search as well.
You can take a standard tach drive dist and make it into a TI. They use the same cast iron body.
There is something different in the body casting. My mechanic even took it to a machine shop to see it they could modify it to work but they said no. Otherwise I would have used it. I too have been piecing together parts for a TI system for my 1966 L72 car. I put a new wiring harness in the car and bought the TI harness as well. I just recently bought an NOS TI coil, a TI amp box, pole piece and another part but still need a distributor. I don’t have to tell you these parts are EXPENSIVE. It seems like a lot of these L72 cars are missing this system. Years ago I had a loaded 1966 390 h.p. coupe that had TI and I remember I had to buy some kind of part for the distributor which was still available but this was back in 1987.
NOPE! As I said both my mechanic and the machine shop said it could not be done. I have a freshly rebuilt tach drive distributor for the car and they had both of them side by side. I don’t recall EXACTLY why it could not be done so if you know all the particulars rather than just something you read in a book and can tell me HOW I have to go with what they said.
